IMUNIFYAV
stephan-ipt
IMUNIFYAV
Post by stephan-ipt »
hi
do you think you can add IMUNIFYAV to keyhelp ?
thnaks
stéphan
prune
Re: IMUNIFYAV
Post by prune »
I agree there is a free version that offers detection only
https://docs.imunifyav.com/stand_alone_mode/
The antivirus log for me shows clamav downloads the signatures successfully but always fails in scanning.
[13-Feb-2023 01:00:01] INFO | start av scanner
[13-Feb-2023 01:00:16] ERROR | av scanner failed: "Abort, anti virus scanner failed."
[13-Feb-2023 01:00:16] INFO | av scanner report:
------------- AV SCAN --------------
Start: 2023-02-13 01:00:01
---------- SCAN LOCATIONS ----------
/home/users
/tmp
/var/tmp
------ UPDATE VIRUS DATABASE -------
End: 2023-02-13 01:00:01
Status: Success
--------------- END ----------------
End: 2023-02-13 01:00:16
Status: Abort, anti virus scanner failed.
Re: IMUNIFYAV
Try run the clamscan command and check for possible errors:
clamscan --infected --recursive --file-list /tmp/keyhelp/anti_virus_scan_paths
prune
Re: IMUNIFYAV
Post by prune »
root@host:~# clamscan --infected --recursive --file-list /tmp/keyhelp/anti_virus_scan_paths
Killed
Re: IMUNIFYAV
You run out of memory?
Re: IMUNIFYAV
obviously you do not have enough RAM vor the AV scanner
prune
Re: IMUNIFYAV
Post by prune »
Alexander wrote: Wed 15. Feb 2023, 11:40 You run out of memory?
Pls see attached. I am not. Maybe I have not set swap properly?
Re: IMUNIFYAV
You are OK because the AV scanner is not running.
You must check it when it runs.
Re: IMUNIFYAV
You can reduce the amount of additional virus signatures "Configuration" -> "Antivirus Scanner" -> "Additional virus signatures".
Than ClamAV will require less RAM.
Re: IMUNIFYAV
prune wrote: Wed 15. Feb 2023, 11:49
Your 32MB ought to be 32GB :)
prune
Re: IMUNIFYAV
Post by prune »
@alexander
It is set to custom and the box is empty
Is it possible to set the swap to 4 gb in keyhelp admin?
@24unix
The vps has only 2 gb ram
Re: IMUNIFYAV
no, you either need a bigger swap parttion or you create a swapfile.
Both cannot be done in Keyhelp.
Re: IMUNIFYAV
prune wrote: Wed 15. Feb 2023, 12:13 @24unix
Then you should use at least 4GB Swap.
But 32MB(!) are useless.
BasHeijermans
Re: IMUNIFYAV
Post by BasHeijermans »
Also, edit /etc/clamav/clamd.conf and add at the bottom: ConcurrentDatabaseReload no
This will reduce memory consumption during AV database updates a lot and stops overloading the system.
Don't know if Alex made this standard when setting low-memory-AV-checking.
Greetings Bas.
prune
Re: IMUNIFYAV
Post by prune »
BasHeijermans wrote: Wed 15. Feb 2023, 17:23 Also, edit /etc/clamav/clamd.conf and add at the bottom: ConcurrentDatabaseReload no
Thanks I just did add that in clamd.conf
I deleted the 32M swap file and I tried to create a new one with 2048M but I get this error
fallocate: fallocate failed: No space left on device
I am thinking of just disabling the virus scanner since it always fails to run anyway. Is there any cloud alternative available with no signatures locally download and loaded?
