[ERROR] Copia de seguridad en el servidor server.puntonetinformatica.es | Repositorio: copiasenatom (FTP(S))
PuntonetSvb
Post by PuntonetSvb »
I am constantly getting errors of this type when making backups, I make copies on other servers and every so often I get these errors that it could not be completed in external repositories and sometimes in the local repository, how can I get the copies to be made? correctly?
[ KeyHelp Control Panel ]
Hola DebianServer!
Una operación de copia de seguridad ha finalizado con el siguiente estado: ERROR
Servidor: server.puntonetinformatica.es
Tipo de copia de seguridad: Copia de seguridad del servidor
Descripción: La operación de copia de seguridad se ha cancelado debido a errores irrecuperables.
Mensajes registrados:
Failed to create backup: Save(<data/e98ad833d3>) returned error, retrying after 26.5363577s: server response unexpected: 500 Internal Server Error (500)
rclone: 2023/02/25 01:24:58 ERROR : data/eb/eb553f15e5970de98e75c4f2e80264d3a68ab8bb6d0f215884404cd4e57b4da8: Post request put error: update stor: 1 error occurred:
rclone: * 450 Transfer aborted. Link to file server lost
rclone:
rclone: 2023/02/25 01:24:58 ERROR : data/eb/eb553f15e5970de98e75c4f2e80264d3a68ab8bb6d0f215884404cd4e57b4da8: Post request rcat error: update stor: 1 error occurred:
rclone:
Save(<data/eb553f15e5>) returned error, retrying after 15.321836548s: server response unexpected: 500 Internal Server Error (500)
rclone: 2023/02/25 01:25:00 ERROR : data/f7/f77e786e12f08927db30319c6f12c83ce9d4ef1fc9ccfd55b745ef78f97c739e: Post request put error: update stor: 1 error occurred:
rclone:
rclone: 2023/02/25 01:25:00 ERROR : data/f7/f77e786e12f08927db30319c6f12c83ce9d4ef1fc9ccfd55b745ef78f97c739e: Post request rcat error: update stor: 1 error occurred:
rclone:
Fatal: unable to save snapshot: server response unexpected: 500 Internal Server Error (500)
Saludos,
su equipo de soporte
Este mensaje se generó automáticamente.
Por favor, no responda a este correo electrónico.
Re: [ERROR] Copia de seguridad en el servidor server.puntonetinformatica.es | Repositorio: copiasenatom (FTP(S))
This is very likly a TLS issue on the remote server.
1) Check, which FTP server software and version is running on the remote.
2) Ensure all versions on the remote servers are up-to-date.
3) Check if the remote is compatibility (in regards to TLS) with your server.
PuntonetSvb
son cuatro servidores con keyhelp con la version 1 de TLS
viewtopic.php?p=29836#p29836
Please stick to English in this forum area.
In this special case I recommend pure FTP (no SSL).
this works everytime and this is no lack of security since the backup is encrypted ootb.
Just upgrade the servers to Ubuntu 22 / Debian 11 should fix the issue, as this will install the proFTPD version (>= 1.3.7), which is not affected by this bug.
PuntonetSvb
I have all the servers with debian 11 or ubuntu 22, but it keeps happening to me, I create another ftp account on the server to which I am going to make the copy and I configure another repository in which I am going to make the backup, and it works for a few days, then the error returns and once it gives it once it doesn't remove it even if I delete the repository and recreate it, I have to create a new ftp account on the server where I keep the copies.
PuntonetSvb
Alexander wrote: Tue 28. Feb 2023, 09:45 Just upgrade the servers to Ubuntu 22 / Debian 11 should fix the issue, as this will install the proFTPD version (>= 1.3.7), which is not affected by this bug.
I have updated the systems with version 1.3.7 of proftpd and it keeps giving me these errors, I delete the entire repository and its content, I create it again and after a few days it happens again, it happens on all the servers, and everyone has debian 11.8
What FTP software is running on the destination side?
The software on the source server is not relevant.
PuntonetSvb
It is the same, all servers have keyhelp installed, with proftp 1.3.7, in fact if I delete the repositories it works again for a few days
