Fail2ban too large  [SOLVED]
lmarcos
Fail2ban too large
Post by lmarcos »
Just one question, is it safe to leave just one or two fail2ban.sqlite3.date files?
I have like 12 files using more than 7 Gb combined and I'm not sure if there is some way to either reduce the amount of files or the amount of days they're kept or if there is a reason behind Keyhelp's decission to keep them there.
Re: Fail2ban too large  [SOLVED]
it is not a decission of Keyhelp, it is done by fail2ban. Normally it is safe to empty the sqlite file when it is to big
lmarcos
Post by lmarcos »
Thanks :D
