Postfix not logging to /var/log/
BasHeijermans
Post by BasHeijermans »
Just a remark rather then a big issue.
There has been a change in the way logging etc happens, but because of that logging to /var/log often doesn't happen.
I have been searching for weeks to find out why it does that.
Turns out, all that is needed is edit /etc/systemd/journald.conf and alter this line from No to Yes:
ForwardToSyslog=yes
then just a:
systemctl restart systemd-journald
is needed and it starts logging again.
Could KeyHelp check for this line and alter it? As many of us are used to tail the logs for problems and I was stunned to see the logs to be empty.
Thank you!!
Greetings Bas.
