Multiple DKIM Selectors  [SOLVED]
latifolia
Post by latifolia »
Hi there,
Our domain has multiple mail servers (primary server with +2 backup servers), separated in different geographical locations.
Our domain is managed in Coudflare so everyhting related to DNS is in Cloudflare.
Or problem is that, any email sent from primary server will get sent with DKIM PASS, while other backup servers will resulted in DKIM FAIL, mostly because the DKIM registered in Coudflare is only from Primary server and we can not put mutiple DKIM in Cloudlfare because it will overlap in same DKIM selector (default._domainkey).
Is that possible we can get custom DKIM selector in KeyHelp so then we can put in Cloudflare:
default._domainkey ...
backup-0._domainkey
backup-1._domainkey
as for now Keyhelp only provide default._domainkey as the only DKIM selector.
Maybe this is considered as feature request.
Thank you.
DiamantTh
Re: Multiple DKIM Selectors
Post by DiamantTh »
+1
The choice/naming of the names I think should also be possible
MfG
Re: Multiple DKIM Selectors  [SOLVED]
This will be a feature of the next KeyHelp Version ;).
