Upload Failed via FM
martins
Post by martins »
Dear devs,
I recently upload a zip file with the size approx. ~30MB. Just about 1 minute, the panel suddenly unreachable and gave me the error message 'This site can’t be reached'. When I refresh the page, it shows me the login page instead.
Btw, I already set up the max. upload file up to 100MB.
Thanks in advance,
tcht
Re: Upload Failed via FM
Post by tcht »
I have the same problem!
Running KH in the latest version with Ubuntu 20, 22 and Debian 12...
Fodos have the same problem.... VERY SLOW!
Please make a tracert / traceroute and post the result here.
you should check the Apache Error Log under /var/log/apache2 and /var/log/apache2/keyhelp Also check the PHP-FPM Log under /var/log/phpX.X-fpm.log
tcht
Post by tcht »
Florian wrote: Fri 13. Oct 2023, 10:35 Hallo,
No errors, no failure records, etc...
It's simply too slow, and I can't play anything on it...
tcht wrote: Fri 13. Oct 2023, 16:30
Sorry but your Thread is here: viewtopic.php?t=12721
