Upgrade php version from 7.4 to 8.1
boka003
Post by boka003 »
Hello there,
How can I upgrade PHP version from 7.4 to 8.1 at KeyHelp 23.0 with Ubuntu 20.04.6 LTS?
I need it on this website; https://webinfo.me/update
Regards
Re: Upgrade php version from 7.4 to 8.1
1) Install the PHP Interpreter: Configuration -> PHP-Interpreters
2) Switch the PHP Interpreter for the Domain: Domains -> Edit Domain -> PHP-Interpreter
boka003
Post by boka003 »
Sorry i forgot to say that server use amd64: https://prnt.sc/-XpML29E4n57
I will need to set 8.1 as the default PHP version.
So, I have installed PHP 8.1 direct on the server, but it is not showing inside key help.
amd64
amd64 or arm64?
How did you install those PHP versions?
How did you do that?
By the way you can also upgrade to Ubuntu 22 and will have PHP 8.1 by default.
boka003
Post by boka003 »
Sorry, it is arm64.
I have installed 8.1 using this tutorial: https://medium.com/@laraveltuts/how-to- ... 18e7565c41
With the upgrade, we will not use any data ?
I can see that Oracle support 22.04 https://forums.oracle.com/ords/apexds/p ... 4-lts-6896
Regards
boka003
Post by boka003 »
ubuntu@ch1:~$ php -v
PHP 8.2.4 (cli) (built: Mar 16 2023 14:34:24) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.2.4, Copyright (c) Zend Technologies
    with Zend OPcache v8.2.4, Copyright (c), by Zend Technologies
ubuntu@ch1:~$
https://prnt.sc/0huGXpS2Ax2U
Here is the difference between server and key help.
How can I update keyhelp too?
please explain in detail what yo have done. Did you do a dist upgrade?
Most important thing: You must not !!!!! change the default PHP version of the OS
boka003 wrote: Thu 6. Apr 2023, 10:31 Sorry, it is arm64.
The additional PHP interpreters provided by KeyHelp do not support arm64 systems.
