How to delete old backups  [SOLVED]
rogernet
Post by rogernet »
How do I delete old backups leaving only the last one? I have almost 10GB of backup and would like to delete the old ones. I already looked in the local repository folder but I didn't find the files with the sizes referring to what is shown in the panel.
Obs. I use the local repository.
Re: How to delete old backups
rogernet
Post by rogernet »
I tried using the commands from the documentation but I couldn't remove it.
What did you do?
What was the result?
Error messages?
Re: How to delete old backups  [SOLVED]
@unix
Please stop sending such things (1st comment) without any context! This is like changing the system PHP version of KeyHelp and later ask "Why does my KeyHelp not work". I mean, if someone would like to break the system in the long run, sure go for things like that...
@rogerio
Do you want to reduce the snapshot count (and therefor the size) of a backup?
-> Go to Backup -> Repository management -> select the repository you like -> and set the max snapshot counter to a value you like.
Shortly, a new backup maintenance job will start and delete the old snapshots.
rogernet
Post by rogernet »
Alexander wrote: Tue 11. Apr 2023, 10:46 @unix
@rogerio
Thank you Alexander and I look forward to the new functions. Greetings.
