Scheduled Tasks Processing but not showing in admin_process_manager
helping_hands1
Post by helping_hands1 »
Regarding task:
Command: nohup php PATH/artisan queue:work --daemon &
Schedule: After server reboot
Owner: redacted (non-root user)
I've scheduled above task, for first time to run, I clicked on Run now from actions. After server reboot, the task message is showing Status: Processing but inside process manager I cannot see the process. So I again click on Run Now from action.
Now it showing two messages but in process manager only one process is running.
I clicked on "Click here to remove all pending and finished tasks at once." but still showing this messages.
Re: Scheduled Tasks Processing but not showing in admin_process_manager
helping_hands1 wrote: Sat 3. Jun 2023, 19:05 Regarding task:
Why do you use nohup?
Are you in fear that the local shell loses connection to the host? :)
And: Remove the ampersand, that sends the process to the background. Probably not what the scheduler expects.
Edit: nohup was a workaround for unreliable dialup connections, later replaced by screen and even later tmux.
In a local environment you don't need it.
helping_hands1
Thanks for your reply.
But I have to run that task at background that's why I used &.
helping_hands1 wrote: Wed 7. Jun 2023, 18:24 Hi,
As I can't glimpse through the code, i just can guess: Scheduled task might always be running in the background.
Did you try it without the ampersand?
None of my background tasks scheduled via keyHelp have the ampersand.
