Disabled SSL-domain not redirecting correctly  [SOLVED]
Grts
Post by Grts »
Disabled SSL domains doesn’t redirect correctly.
Debian 11
23.1.1 (Build 3016)
When visiting a disabled domain using SSL (https) it displays ”page not found”. When visiting the same domain using non-SSL (http) i redirects correctly as per defined settings.
Expected result
Disabled domains should redirect with SSL to ”disabled domain-url” and not display ”page not found”.
Additional information / possible fix
When an administrator disables a domain then the config is uppdated with only the *:80-block and completely removes *:443-block which makes it ”not found”.
When manually adding the *:443-block to the config file again it works as it should but these lines are removed by KeyHelp on next update.
Re: Disabled SSL-domain not redirecting correctly  [SOLVED]
Fixed for KH 23.2.
(You may have to trigger a domain config rewrite to make it work after the update.)
