Services LE SSL for more than one domain
theqkash
Post by theqkash »
I'm currently migrating several i-MSCP instances into one keyhelp instance.
I have an issue:
I've been using several server addresses as there was several instances of i-MSCP. Now I'm making from those one large keyhelp instance. Clients were using different addresses of IMAP/POP/SMTP addresses with SSL.
I was unable to find an option to set several domains to be handled as IMAP/POP/SMTP address with LE for SSL for all of those. I would like to not notify users to change settings of their mail clients, but to maintain LE certificate for several domains for mail.
Is that possible here?
Re: Services LE SSL for more than one domain
theqkash wrote: Mon 25. Sep 2023, 03:22 I'm currently migrating several i-MSCP instances into one keyhelp instance.
Have you seen this? ->
Migration von i-MSCP zu KeyHelp
There is a script to migrate from i-MSCP to KeyHelp.
But it's in the german forum section (try DeepL or Google Translator ;) ).
Yes it is.
Customers can use their own domainname as mailservername in the settings of an email software.
theqkash
Post by theqkash »
I don't know if I made the right statement.
I have had several servers on i-MSCP so far. That servers had hostnames like:
v1.domain.de v2.domain.de etc.
Users was using that addresses to connect to IMAP/SMTP with SSL and I have generated LE certificates for that addresses from i-MSCP control panel.
In i-MSCP, with the Let's Encrypt SSL certificate that is generated for email services, I could indicate that this certificate should be generated for more addresses. So in the extreme case of clients I could even add that on their i-MSCP server in addition to v1.domain.de they could use for example mail.client-domain.de.
However, I don't see in keyhelp an option to have the Let's Encrypt SSL certificate for mail services generated for more domains. And what I would like to do is to make it so that customers can still use mail services with me without reconfiguring their mail clients, because currently they have v1.domain.de, v2.domain.de etc and in my keyhelp installation the hostname is simply hosting.domain.de and I would like the SSL certificate for hosting.domain.de that mail services use to also include the addresses I indicated such as v1.domain.de, v2.domain.de etc.
