Debian 12 Upgrade
- LastSavingGrace
Debian 12 Upgrade
I have just performed the Debian 12 Bookworm upgrade. Everything seems to have gone ok, but when I try to access Keyhelp now I see:
Service Unavailable
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Websites all seem to load ok. Is there a command to restart Keyhelp? Or another one way to fix the error? I tried a reboot already.
Many thanks.
Re: Debian 12 Upgrade
keyhelp toolboxData Collector für Community Support
- LastSavingGrace
- BasHeijermans
- KeyHelp Translator
I solved them bij 're-configuring' all servers, just SAVE at all of them, via the webpanel.
Then goto the keyhelp-toolbox and select rewrite USER and CONFIG files, options 1 and 2.
After that and waiting for about 5 minutes, all started working again.
Hopefully this helps.
Hello,LastSavingGrace wrote: ↑Sat 28. Oct 2023, 07:15 Hi Guys,
Service Unavailable
Many thanks.
After the first reboot, you have to run the upgrade script again (as per instructions before reboot).
You did that?
Best
- LastSavingGrace
Yes, did that. BasHeijermans, thanks for the help, I will try your suggestion.andromeda wrote: ↑Sat 28. Oct 2023, 18:16Hello,LastSavingGrace wrote: ↑Sat 28. Oct 2023, 07:15 Hi Guys,
Service Unavailable
Many thanks.
You did that?
Best
- LastSavingGrace
