Emails going to spam [SOLVED]
Re: Emails going to spam
and DKIM?
It is good that the resource records are present in the DNS, but are they correct?
If we are to help you really, then we need at least the domain in order to be able to check the DNS records for correctness from the outside.
my domain vanixweb.com
actually the problem when i store an SPF record its stored without spaces
I typed
v=spf1 mx a include:relay.mailbaby.net ~all
when in use the lookup in getting
v=spf1mxainclude:relay.mailbaby.net~all
;QUESTION
vanixweb.com. IN ANY
;ANSWER
vanixweb.com. 3600 IN TXT "v=DMARC1"
vanixweb.com. 3600 IN TXT "v=spf1" "mx" "a" "include:relay.mailbaby.net" "~all"
vanixweb.com. 3600 IN NS ns.vanixweb.com.
vanixweb.com. 3600 IN NS ns2.vanixweb.com.
vanixweb.com. 3600 IN A 176.117.72.155
vanixweb.com. 3600 IN SOA ns1.vanixweb.com. support.vanixweb.com. 2023112133 14400 1800 604800 3600
;AUTHORITY
;ADDITIONALThe MX resource record is completely missing.
The SPF resource record should look like this:
vanixweb.com. 3600 IN TXT "v=spf1 mx a include:relay.mailbaby.net ~all"The PTR record is pointing to the wrong host
;QUESTION
155.72.117.176.in-addr.arpa. IN PTR
;ANSWER
155.72.117.176.in-addr.arpa. 14400 IN PTR maltanet.net.
;AUTHORITY
;ADDITIONALData Collector für Community Support
Make sure to place quotation marks at the beginning and end of the value.
Your DKIM resource record is also not correct:
;QUESTION
default._domainkey.vanixweb.com. IN TXT
;ANSWER
default._domainkey.vanixweb.com. 3600 IN TXT "v=DKIM1; h=sha256; k=rsa; s=email; " "p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAu6GiePrhoNQ10T2Je4VTCRnaFARWyjy7qFz+73rG1jv1TAgy611hJFaVAOWPYnP3JJ7/ybauNG03P/Lyudtx7Oeqpq5WmaDh4+WQYjCynQsTGtydWrEzidsZhyVgeRbTRrisHBPmrNi5qKtH8M5DslpI4FXTT2gEAebbUqau+jebfc4hATPpygoitQlSpgkEXfAoQQNwB2dK3S" "O2YTHp+UBfJ6kxDC6/tC4Wf1wFc6dt31oQlkvLtSldULHiNHqIqCDAFAOyzMkb1rX6nWbJ4RNt/Oo5XbgF2O8eQbNbneSPI2myGXVeF8is8DkAmYUhCzDTw54azfhplKhl2sEllQIDAQAB"
;AUTHORITY
;ADDITIONALCode: Select all
default._domainkey.vanixweb.com. 3600 IN TXT "v=DKIM1; h=sha256; k=rsa; s=email; p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAu6GiePrhoNQ10T2Je4VTCRnaFARWyjy7qFz+73rG1jv1TAgy611hJFaVAOWPYnP3JJ7/ybauNG03P/Lyudtx7Oeqpq5WmaDh4+WQYjCynQsTGtydWrEzidsZhyVgeRbTRrisHBPmrNi5qKtH8M5DslpI4FXTT2gEAebbUqau+jebfc4hATPpygoitQlSpgkEXfAoQQNwB2dK3S" "O2YTHp+UBfJ6kxDC6/tC4Wf1wFc6dt31oQlkvLtSldULHiNHqIqCDAFAOyzMkb1rX6nWbJ4RNt/Oo5XbgF2O8eQbNbneSPI2myGXVeF8is8DkAmYUhCzDTw54azfhplKhl2sEllQIDAQAB"
Please read carefully what was written:
BTW:
If you use the IPv6 protocol on your server, you should also set the corresponding AAAA resource records.
I have only ipv4 and whats is the correct PTR?
vanixweb.com ------- ip
ip----------- vanixweb.com
It should look like this:
155.72.117.176.in-addr.arpa. 14400 IN PTR server1.vanixweb.com.Let's take a look at your MX Resource Records now:
;QUESTION
vanixweb.com. IN MX
;ANSWER
vanixweb.com. 3600 IN MX 10 aspmx3.googlemail.com.vanixweb.com.
vanixweb.com. 3600 IN MX 10 server1.vanixweb.com.
vanixweb.com. 3600 IN MX 5 alt2.aspmx.l.google.com.vanixweb.com.
vanixweb.com. 3600 IN MX 1 aspmx.l.google.com.vanixweb.com.
vanixweb.com. 3600 IN MX 10 aspmx2.googlemail.com.vanixweb.com.
vanixweb.com. 3600 IN MX 5 alt1.aspmx.l.google.com.vanixweb.com.
;AUTHORITY
;ADDITIONALI'm afraid you don't really know what you're doing...Why are these MX Resource records?
I think, your MX resource record should look like this:
vanixweb.com. 3600 IN MX 10 server1.vanixweb.com.Data Collector für Community Support
