Create a plugin  [SOLVED]
soufian
Create a plugin
Post by soufian »
can we create a plugin and add it to the theme?
like creating a PHP or Twig file to download WordPress and install it for the user
Re: Create a plugin
Hello
No.
add it to the theme
Let's rename it to "add a theme" which is possible.
You can use KeyHelp Pro for that, which comes with a One-Click installer for Apps like this.
https://www.keyweb.de/en/keyhelp/keyhel ... ement-tool
soufian
Re: Create a plugin
Post by soufian »
I'm just giving an example with WordPress
And i have another question why are subdomains created on the main directory like a subfolder
when user visit
example.com/subdomain.example.com it's showing the website
Re: Create a plugin
you can configure the folder for a subdomai when creating the subdomain.
soufian
Re: Create a plugin
Post by soufian »
What I mean
other folders
www
public_html
-index.html
-subdomain.example.com
should be something like this
other folders
www
public_html
-index.html
Re: Create a plugin
the webfolder is www
You can create subfolders for every domain and subdomain under this www folder
soufian
Re: Create a plugin
Post by soufian »
but the subdomain is accessible from the main domain
like this
example.com/demo.example.com
Re: Create a plugin
you create www/domain folder for the domain
and www/subdomain for the subdomain
So the subdomain folder is not reachable from the domain and vice versa
Re: Create a plugin  [SOLVED]
Than you may want to create something like that:
Bildschirmfoto vom 2023-12-04 15-48-18.png (18.14 KiB) Viewed 28933 times
You are totally free, in how you organize your www/ directory.
(With the upcoming release, KeyHelp will help creating things like that more easily by suggesting folder names)
