Increased of Disk usage after restore
Chalipa
Post by Chalipa »
(Problems not related to KeyHelp belong in the Offtopic forum)
Debian 12.2 (64-bit)
XEN
23.2.1 (Build 3125)
I have restored only users after server migration to the new host, I had 250GB of data but when I restored users now I see the used disk size 520GB
Expected result
250GB disk space used
Actual result
520GB disk space used
Steps to reproduce
Additional information
[02-Dec-2023 01:34:02] INFO | Create repository lock
[02-Dec-2023 01:34:03] INFO | Looking for pending operations for repository: restore (FTP(S)) / #1
[02-Dec-2023 01:34:03] INFO | Operation found: check
[02-Dec-2023 01:34:03] INFO | Integrity check
[02-Dec-2023 01:34:07] INFO | Update snapshot data / stats
[02-Dec-2023 01:34:16] INFO | Update repository stats
[02-Dec-2023 01:34:21] INFO | Size 'raw': 234.98 GiB
[02-Dec-2023 01:34:21] INFO | Size 'restore': 468.34 GiB
[02-Dec-2023 01:34:22] INFO | All finished, releasing lock.
[02-Dec-2023 01:48:01] INFO | Create repository lock
[02-Dec-2023 01:48:03] INFO | Looking for pending operations for repository: restore (FTP(S)) / #1
[02-Dec-2023 01:48:03] INFO | Operation found: restore
[02-Dec-2023 01:48:03] INFO | Prepare restore...
[02-Dec-2023 01:48:03] INFO | Restore paths...
[02-Dec-2023 02:53:06] INFO | Final cleanup
[02-Dec-2023 02:53:13] INFO | All finished, releasing lock.
Where do I find these extra 250GB backup and delete them?
Re: Increased of Disk usage after restore
these remaining data could be databases or emails.
Have you checked the real consumption on the disk of webspace, emails and databases?
Chalipa
Post by Chalipa »
Alexander wrote: Wed 6. Dec 2023, 09:35 Hello,
There were no emails or databases, just backup files (.tar.gz extensions).
You can use "KeyHelp Admin Area -> General -> System Status -> Disk Usage" to investigate where your files are.
Where did you have these numbers from: "I had 250GB of data but" and "I see the used disk size 520GB".
You may also want to check via the CLI tools of you operating system, how big your folders are etc.
You will sure understand, that it is hard to investigate as no one on this forum knows, what is happening on your disk. You need to provide as much information as possible. Post screenshots etc...
pandinusimperator
Post by pandinusimperator »
Chalipa wrote: Wed 6. Dec 2023, 00:15
Uncompressed, restored data 468 GB plus operating system and stuff - 520GB disk usage sounds somehow reasonable to me.
