Change of Keyhelp IP in database ?  [SOLVED]
amarc
Post by amarc »
well I have specific scenario where Keyhelp is in VM with some IP. I need to move that VM to different host/location and that IP will change.
Is there a way to do:
- stop current Keyhelp VM
- move VM to another host
- give VM new IP and start it
- go to Keyhelp's DB and change it's IP within DB to new IP
Why I need to do this ? Simply because, as I see it, I can't do it otherwise. I can't change it while running on current host as new IP is not available to that host and I can not start it on new host with old VM/Keyhelp IP for same reason.
ty.
Re: Change of Keyhelp IP in database ?  [SOLVED]
Currently you can go into the database and update the values there. There will be an option in the 'keyhelp-toolbox' in the future, to update IPs there.
You can use this command:
mysql -D 'keyhelp' -e "UPDATE settings SET value = '111.111.111.111,222.222.222.222' WHERE category = 'dns' and name = 'ips'";
And replace 111.111.111.111 and 222.222.222.222 with your IPs. Do not use more than 2 IPv4 and/or 2 IPv6.
Than go to keyhelp-toolbox and let it rewrite all the config files.
Be advised, that you have to setup your IPs in network configuration of your system. KeyHelps IPs in the database are "only" for writing Apache and Bind configuration files.
amarc
Post by amarc »
Thanks. Yes, VM will have new IP as that is managed "externally" by DHCP there is no static configs regarding network anywhere.
