Not receiving mail after upgrading to version 24.0 (Failed to start Interface between MTA and virus scanner/content filt  [SOLVED]
athensguy
Post by athensguy »
amavis service stopped and unable to restart and fails with below error Failed to start Interface between MTA and virus scanner/content filters.
systemctl status amavis
× amavis.service - Interface between MTA and virus scanner/content filters
     Loaded: loaded (/lib/systemd/system/amavis.service; enabled; vendor preset: enabled)
     Active: failed (Result: exit-code) since Mon 2024-02-12 10:09:24 EET; 3s ago
       Docs: http://www.ijs.si/software/amavisd/#doc
    Process: 16398 ExecStartPre=/usr/bin/find /var/lib/amavis -maxdepth 1 -name amavis-* -type d -exec rm -rf {} ; (code=exited, status=0/SUCCESS)
    Process: 16399 ExecStartPre=/usr/bin/find /var/lib/amavis/tmp -maxdepth 1 -name amavis-* -type d -exec rm -rf {} ; (code=exited, status=0/SUCCESS)
    Process: 16400 ExecStart=/usr/sbin/amavisd-new foreground (code=exited, status=255/EXCEPTION)
   Main PID: 16400 (code=exited, status=255/EXCEPTION)
        CPU: 1.168s
Feb 12 10:09:24 Keyhelpsrv systemd[1]: amavis.service: Scheduled restart job, restart counter is at 5.
Feb 12 10:09:24 Keyhelpsrv systemd[1]: Stopped Interface between MTA and virus scanner/content filters.
Feb 12 10:09:24 Keyhelpsrv systemd[1]: amavis.service: Consumed 1.168s CPU time.
Feb 12 10:09:24 Keyhelpsrv systemd[1]: amavis.service: Start request repeated too quickly.
Feb 12 10:09:24 Keyhelpsrv systemd[1]: amavis.service: Failed with result 'exit-code'.
Feb 12 10:09:24 Keyhelpsrv systemd[1]: Failed to start Interface between MTA and virus scanner/content filters.
Checking mail log (hided yahoo email for privacy reasons)
Feb 12 09:33:13 Keyhelpsrv postfix/smtp[6835]: 46A137E061: to=<#####@yahoo.com>, relay=none, delay=1704, delays=1704/0.01/0/0, dsn=4.4.1, status=deferred (connect to 127.0.0.1[127.0.0.1]:10024: Connection refused)
Simply nothing changed on server settings. It was only the update that break it down I think.
Please help me fix that
Re: Not receiving mail after upgrading to version 24.0 (Failed to start Interface between MTA and virus scanner/content
Please fill out the template for new topics in this forum the next time.
Otherwise a mod will very likly close the topic immediately.
You may want to try these commands:
systemctl reset-failed amavis.service
systemctl start amavis.service
(viewtopic.php?p=37130#p37130)
athensguy
Post by athensguy »
Alexander wrote: Mon 12. Feb 2024, 12:41 Hello,
I will consider using templates from now on.
The reset service command did not help
athensguy
Re: Not receiving mail after upgrading to version 24.0 (Failed to start Interface between MTA and virus scanner/content   [SOLVED]
Post by athensguy »
Alex, thanks for your help.
After removing the amavis and re-install/configure, it works as expected.
