How to increase FastCGI limits?
boka003
Post by boka003 »
Hello there,
Problem 1. My WP website is not able to update or install new plugins: https://prnt.sc/teNLweSkqitC
I have not found any error about this in my error logs.
Problem 2. But I have found this log when I try to save changes at some plugin configuration:
(104)Connection reset by peer: [client 192.168.111.50:52441] AH01075: Error dispatching request to : (reading input brigade),
 400	POST /wp-admin/admin-ajax.php HTTP/1.1
https://prnt.sc/_OoZBrlMBX0X
Then I have found how to do it at Plesk;
https://support.plesk.com/hc/en-us/arti ... request-to
https://bobcares.com/blog/plesk-ah01075 ... equest-to/
Can this be a solution to my problem?
And how I can increase these values at KeyHelp?
I was not able to find fcgid.conf file.
Regards
Re: How to increase FastCGI limits?
this has nothing to do with timeouts. You see the error in your screenshot:
"wordpress could not establish a secure connection to wordpress.org"
So check your outgoing connections and name resolution on your system
boka003
Post by boka003 »
Thank you for your reply.
I have updated my topic (problem 1 and problem 2).
Problem 1 is a possible network issue, as the server is in the internal network.
But, can problem 2 be solved by editing these values?
Here is my keyhelp.conf file
listen = /run/php/keyhelp_keyhelp.socket
listen.owner = keyhelp
listen.group = keyhelp
listen.mode = 0666
user = keyhelp
group = keyhelp
pm = ondemand
pm.max_children = 20
pm.max_requests = 20
env[TMP] = /tmp/keyhelp/
env[TMPDIR] = /tmp/keyhelp/
env[TEMP] = /tmp/keyhelp/
php_admin_value[sendmail_path] = /usr/sbin/sendmail -t -i -f boris@po1111111.org
php_admin_value[open_basedir] = /
php_admin_value[session.save_path] = /tmp/keyhelp/
php_admin_value[upload_tmp_dir] = /tmp/keyhelp/
php_admin_value[memory_limit] = 17777M
php_admin_value[post_max_size] = 17777M
php_admin_value[upload_max_filesize] = 17777M
php_admin_value[max_execution_time] = 340
php_admin_value[max_input_vars] = 8000
fix the connection errors and check if the other error occurs again. It seems that is is simply a follow-up error
boka003
Post by boka003 »
This is a database connection plugin, and that database is inside our internal network too.
I can access it using Postman.
The database is big, and maybe increasing FastCGI limits can help?
Because, database connection is successful, but the import shows that error.
Can you please tell me where I can increase those limits?
Regards
in /etc/apache2/mods-enabled/fcgid.conf
Florian wrote: ↑Wed 20. Mar 2024, 13:58 in /etc/apache2/mods-enabled/fcgid.conf
hmm... is fcgid really (still) required when using FPM with mpm-event?
just deactivated (a2dismod fcgid) it for a check & restarted apache and my default PHP interpreter - so everything works much faster w/o fcgid ... or is it needed for the compiled PHP interpreters?
I just answered the question where to adjust the values for FastCGI. I have not answered the question of meaning.
Florian wrote: ↑Wed 20. Mar 2024, 16:50 I just answered the question where to adjust the values for FastCGI. I have not answered the question of meaning.
agreed ;-)
since KH uses fpm w/ mpm-event (as default) wouldn't it be better when fcgid is set disabled then?
It seems to me that apache perform a little better ...
after disabling it shows
~# apachectl -M | grep 'proxy'
 proxy_module (shared)
 proxy_fcgi_module (shared)
just like before
boka003
Post by boka003 »
Can you please help me debug this error at my website: https://prnt.sc/F590rSKF4uOG
It shows up when I try to update plugins.
Regards
Moderator Notice:
Please attach screenshots as files to your posts in the future.
