Ubuntu is a VM on Hyper-V. Not new, but recent. Fully updated.
Trying to follow https://wiki.keyhelp.de/books/installat ... stallation to install Keyhelp to try it out bit before maybe setting up a VPS at KeyWeb, but it fails with the following:
--2024-04-05 12:03:55-- https://install.keyhelp.de/get_keyhelp.php
Resolving install.keyhelp.de (install.keyhelp.de)... 62.141.56.232, 2001:1b60:2:11:913:101:be57:cafe
Connecting to install.keyhelp.de (install.keyhelp.de)|62.141.56.232|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [text/x-sh]
Saving to: ‘install_keyhelp.sh’
install_keyhelp.sh [ <=> ] 15.24K --.-KB/s in 0.03s
2024-04-05 12:03:56 (448 KB/s) - ‘install_keyhelp.sh’ saved [15610]
You are about to install KeyHelp.
Running system checks...
Installing certificates...
Installing PHP...
Selecting previously unselected package php.
(Reading database ... 151367 files and directories currently installed.)
Preparing to unpack .../0-php_2%3a8.1+92ubuntu1_all.deb ...
Unpacking php (2:8.1+92ubuntu1) ...
Selecting previously unselected package php8.1-intl.
Preparing to unpack .../1-php8.1-intl_8.1.2-1ubuntu2.14_amd64.deb ...
Unpacking php8.1-intl (8.1.2-1ubuntu2.14) ...
Selecting previously unselected package php-intl.
Preparing to unpack .../2-php-intl_2%3a8.1+92ubuntu1_all.deb ...
Unpacking php-intl (2:8.1+92ubuntu1) ...
Selecting previously unselected package php-mbstring.
Preparing to unpack .../3-php-mbstring_2%3a8.1+92ubuntu1_all.deb ...
Unpacking php-mbstring (2:8.1+92ubuntu1) ...
Selecting previously unselected package php-mysql.
Preparing to unpack .../4-php-mysql_2%3a8.1+92ubuntu1_all.deb ...
Unpacking php-mysql (2:8.1+92ubuntu1) ...
Selecting previously unselected package php-readline.
Preparing to unpack .../5-php-readline_2%3a8.1+92ubuntu1_all.deb ...
Unpacking php-readline (2:8.1+92ubuntu1) ...
Setting up php (2:8.1+92ubuntu1) ...
Setting up php-mysql (2:8.1+92ubuntu1) ...
Setting up php-mbstring (2:8.1+92ubuntu1) ...
Setting up php-readline (2:8.1+92ubuntu1) ...
Setting up php8.1-intl (8.1.2-1ubuntu2.14) ...
Creating config file /etc/php/8.1/mods-available/intl.ini with new version
Setting up php-intl (2:8.1+92ubuntu1) ...
Processing triggers for libapache2-mod-php8.1 (8.1.2-1ubuntu2.14) ...
Processing triggers for php8.1-cli (8.1.2-1ubuntu2.14) ...
Scanning processes...
Scanning linux images...
Running kernel seems to be up-to-date.
No services need to be restarted.
No containers need to be restarted.
No user sessions are running outdated binaries.
No VM guests are running outdated hypervisor (qemu) binaries on this host.
Reading package lists... Done
Building dependency tree... Done
Installing KeyHelp...
/tmp/keyhelp.tar.gz 100%[=================================================>] 18.63M 21.0MB/s in 0.9s
Installing ionCube...
/tmp/ioncube.tar.gz 100%[=================================================>] 15.00M 23.2MB/s in 0.6s
Run /home/keyhelp/www/keyhelp/install/install.php --installer-version 1
PHP Warning: Undefined array key "encryption" in /home/keyhelp/www/keyhelp/core/License/License.php on line 140
PHP Warning: Trying to access array offset on value of type null in /home/keyhelp/www/keyhelp/core/License/License.php on line 140
PHP Fatal error: Uncaught mysqli_sql_exception: Variable 'sql_mode' can't be set to the value of 'NO_AUTO_CREATE_USER' in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php:117
Stack trace:
#0 /home/keyhelp/www/keyhelp/core/pending/DBConnection.php(117): mysqli->query()
#1 /home/keyhelp/www/keyhelp/core/pending/DBConnection.php(65): DBConnection->connect()
#2 /home/keyhelp/www/keyhelp/install/install.php(136): DBConnection->__construct()
#3 {main}
thrown in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 117
Stack trace:
#3 {main}
There is zero mention in the setup instructions of making any preparations like making a database or anything else so I an very confident I have followed instructions correctly. CA-certificates is installed and updated.
