Uninstall antivirus and spam asssasin
Re: Uninstall antivirus and spam asssasin
Best way: Just rent a better server.
Hello, you can just disable/mask those services, so they don't even startup. ClamAV chews the most memory.
On my system I didn't require antivirus, so I used this command to do the job:
systemctl mask clamav-daemon clamav-freshclamRe: Uninstall antivirus and spam asssasin
Just a note: There is a checkbox in KeyHelp exactly for this purpose.george wrote: ↑Tue 9. Apr 2024, 01:02 On my system I didn't require antivirus, so I used this command to do the job:
Configuration -> Email Server -> Email virus checks -> [ ] Enabled
