Change the font type of the keyhelp panel [SOLVED]
antonioprog
samsonwilliams
Re: Change the font type of the keyhelp panel
Re: Change the font type of the keyhelp panel [SOLVED]
You can overwrite all styles of the KeyHelp panel.
Just go to 'Configuration' -> 'White Label' -> Edit 'All languages' -> Add the following into the 'Additional CSS' input field:
body
font-family: verdana;
}@samsonwilliams
I have updated your URL as the page you linked to is unofficial and we are not responsible for the content of the page you linked to.
