Upgrade Debian 10 auf Debian 11 scheitert.  [GELÖST]
mumati
Post by mumati »
ja
Debian 10.13 (64-bit)
Root Server
24.0 (Build 3220)
Upgrade nicht möglich
Fehler
/var/log/php.error
[11-Aug-2023 13:53:41 Europe/Berlin] PHP Warning:  session_destroy(): Trying to destroy uninitialized session in /home/keyhelp/www/keyhelp/misc/pma_sso.php on line 83
[07-Jun-2024 01:39:25 Europe/Berlin] PHP Warning:  Invalid argument supplied for foreach() in /home/keyhelp/www/keyhelp/pages/admin_configuration.php on line 176
[07-Jun-2024 01:40:14 Europe/Berlin] MySQL - Connection Error: 2002 (No such file or directory)
[13-Jun-2024 16:17:02 Europe/Berlin] PHP Fatal error:  Uncaught Error: Call to undefined method OperatingSystem::isIdInList() in /root/keyhelp_debian_upgrade_10_to_11.php:151
Stack trace:
#0 {main}
  thrown in /root/keyhelp_debian_upgrade_10_to_11.php on line 151
[13-Jun-2024 16:22:56 Europe/Berlin] PHP Fatal error:  Uncaught Error: Call to undefined method OperatingSystem::isIdInList() in /keyhelp_debian_upgrade_10_to_11.php:151
Stack trace:
#0 {main}
  thrown in /keyhelp_debian_upgrade_10_to_11.php on line 151
ICh wollte meinen alten Server von Debian 10 auf Debian 11 upgraden und bei der Installation kamm diese Meldung. Muss ich vorher noch was einstellen ?
> Pre-checking system...
Fatal error: Uncaught Error: Call to undefined method OperatingSystem::isIdInList() in /home/keyhelp/keyhelp_debian_upgrade_10_to_11.php:151
Stack trace:
#0 {main}
  thrown in /home/keyhelp/keyhelp_debian_upgrade_10_to_11.php on line 151
ashosting:/home/keyhelp#
Danke und Grüße
Re: Upgrade Debian 10 auf Debian 11 scheitert.  [GELÖST]
24.0 (Build 3220)
Du musst erstmal auf KeyHelp 24.1 aktualisieren.
Anschließend kannst du das Script problemlos ausführen.
mumati
Post by mumati »
Danke sehr. Manuel aktualisiert, jetzt bekomme ich nächste Error :
Error One or more PHP interpreter are in use, which are unavailable for the upcomming operating system version.
Please update the affected domains to use use a more recent PHP interpreter version.
The following PHP Interpreters cannot be used anymore: 5.3, 5.4
Kein einzige Domain verwendet 5.4 aber unter PHP Intepreter steht bei PHP 5.4 - 1x. Alle Domains aber nutzen PHP 7 und 8.
Wie kann ich rausfinden, welche Domain es nutzt oder kann ich nicht einfach diesen Domain kicken :)
Danke und Grüße
Ich hab es zwar nicht getestet, aber wenn du eine alternative PHP Version deinstallierst, die noch im Panel eingetragen ist, dann sollte eigentlich die Standard PHP Version gesetzt werden.
mumati
Post by mumati »
wie kann ich es manuell deinstallieren, da es nicht über PAnel geht ?
mumati
Post by mumati »
oder besser gefragt. kann ich überhaupt php interpreter manuell deinstallieren, ohne Keyhelp dann scheitert ?
Du verwendest an einer Stelle noch den alten Interpreter. KeyHelp denkt sich das nicht einfach aus.
Vermutung: Du schaust dir über den Keyadmin unter dem Menüpunkt "Domains" die Domains an, aber lässt dir dort keine Subdomains anzeigen (Button: "Ansichts anpassen") und eine Subdomain verwendet halt noch PHP 5.4.
Das geht natürlich, sie darf nur nicht mehr in Verwendung sein.
mumati
Post by mumati »
Alles im Ansicht ist bei mir gewählt und die Subdomains werden auch angezeigt und inkl. Subdomains verwenden alle Domains PHP 7 oder 8 und es gibt im Panel kein Domain, der noch PHP 5.4 verwendet. Kann ich untter Shell irgendwo detailliert anschauen, welche Domain noch PHP 5 verwenden tut ?
Danke und Grüße
Wieviele Domains sind denn auf dem Server drauf? Sortiere die Ansicht mal nach PHP Version, man kann das auch leicht übersehen
mumati
Post by mumati »
68 Einträge mit Subdomains.
Hier ist sortiert nach PHP Version.
Ganz oben ist Sandart PHP 7.3 aufgelistet und sortierung aufwärts, wie folgt :
In der Mitte zeigt er aber PHP 7.0, obwohl Sortierung aufwärts und dann geht wieder aufwärts, wie folgt :
Sende mir mal die Zugangsdaten per PM.
mumati
Post by mumati »
Er ist mein alter Server Alexander und wollte nur testen, wie es ist mit dem Debian Upgrade für die Zukunft.
Wenn Du möchtest, bekommst auch Panel Zugriff von mir, damit Du auch anschauen kannst. Ich finde diese 1x Domain nicht unter Panel.
Danke und Grüße
mumati
Post by mumati »
Upgrade war erfolgreich.
Es gab paar Sachen, die ich nochmal prüfen muss. Gibts irgendwo ein Bericht vom Upgrade, damit ich sehen kann, was lief gut und was nicht und auch welche Dateien ich Standart gelassen habe ? Wenn ich in der Zukunft dann irgendwelche Probleme habe, möchte ich gern die Dateien kennen, welche ich nicht aktualisiert habe. Bei allen Dateien, wo ich gefragt wurde, habe ich default : N genommen.
z.B. bei dem Bild steht cannot open bayes databases, permission denied. Gibs bestimmt irgendwo ein Bericht dafür.
Danke und Grüße
mumati
Post by mumati »
Nach Debian 11 Upgrade funktioniert neue Datenbank anlegen und bearbeiten einwandfrei.
Neue Benutzer anlegen, Neue Email Adresse hinzufügen und Neue Domain Anlegen geht nicht, Im Panel steht in Bearbeitung.
Habe ich bei der Installation was falsches gemacht oder muss ich noch was umändern, damit die Sachen auch funktionieren ?
mumati
Post by mumati »
Oder kann ich gleich auf Debian 12 upgraden, ohne die Probleme zu lösen ?
