Debian or Ubuntu? Which distro is preferred for Keyhelp?
sanxh
Post by sanxh »
:?: Dear Keyhelp, for the last time please mention which distro is preferred for Keyhelp installation, Debian or Ubuntu? And why?
Thanks.
Re: Debian or Ubuntu? Which distro is preferred for Keyhelp?
There is no significant difference between using Debian or Ubuntu, as both operating systems are based on the same kernel. Personally, I prefer Debian, but this is more of a philosophical choice than a technical one.
'm not quite sure, but Debian 12 will definitely get rspamd installed with Keyhelp. I think Ubuntu still comes with amavis. So this would be a significant difference. The rest should be the same for both.
sanxh
Post by sanxh »
Jolinar wrote: Sun 23. Jun 2024, 09:56 There is no significant difference between using Debian or Ubuntu, as both operating systems are based on the same kernel. Personally, I prefer Debian, but this is more of a philosophical choice than a technical one.
But honestly I want to know which distro is good for critical Keyhelp installation.
sanxh wrote: Sun 23. Jun 2024, 12:53
They both will do the job.
But Ubuntu has some flaws like Snapd, which can be a PITA on a server system. Go with the original and don't regret it :-)
If you are a beginner use Ubuntu.
Otherwise choose Debian.
