Webmail's SSL error
sanxh
Webmail's SSL error
Post by sanxh »
I installed Keyhelp and it automatically secured it Let's Encrypt but webmail is not secured and is default. I cannot add Let's Encrypt. The error in the screenshot. How can I do?
Screenshot 2024-06-23 192025.png (4.38 KiB) Viewed 20514 times
Re: Webmail's SSL error
For me the panel looks the same, for webmail is no option for LE.
I think there have been some changes in the past, but as I don’t use webmail I didn’t investigate further.
But I think generally there is room for improvements in KeyHelp regarding webmail and LetsEncrypt.
If you need webmail or want it to offer to customers, you might consider creating a dedicated webmail domain and maintain it yourself.
I’d be glad if anyone can correct me and explain that it is now working out of the box.
Just use the default webmail URL and everything will be fine.
Otherwise use a reverse proxy.
There is no need to install a seperate webmail.
sanxh
Post by sanxh »
How to use reverse proxy?
The answer is in the german section.
viewtopic.php?t=11748
