Server CPU usage config
aardappel
Post by aardappel »
I'm new to keyhelp.
I've setup keyhelp correctly on a 2cp/4gb vps.
Now i'm coming from directadmin and centos and i've had these servers heavily configured and running properly with less specs (2gv/2cpu). With over 20 wordpress websites with low to medium consistent load.
I've added 3 users in keyhelp with each a single wordpress website.
My cpu load for a single user is constantly around 140-750%. Mind this is a multi language wordpress setup with barely any traffic.
On directadmin i have (defaults):
pm.max_children 20
pm.max_requests 500
pm.process_idle_timeout 20
start and spare server aren't even necessarily configured.
From what i understand, every user you create within keyhelp, uses php with it's own settings instead of having a collective pool as in directadmin.
I'm simply look for someone who has keyhelp running stable with an average load of 70% within 24hour. Shouldn't be too hard?
Re: Server CPU usage config
"I'm simply look for someone who has keyhelp running stable with an average load of 70% within 24hour."
Thsi has nothing to do with Keyhelp. It depends on your hardware, the load of your websites, the programming of your websites (including optimizing) and other facts
If you want one pool for all, just use one user. The panel itself doesn't use a lot of resources. I run it on my 1vCore/1GB RAM Server without a problem. Then again, I don't host 20(!) Wordpress(!) sites on it.
aardappel
Post by aardappel »
Yeah i get that it depends on resources. But ive literally dropped 2 no-traffic wordpress installs on it and keyhelp is running stuck completely with 4gb/4cpu vps. And it's php that does the overkill.
I'm trying several open source CPs and keyhelp is not having a good start, so my question if someone has it running with several users/wordpress installs shouldn't be so strange considering the wide usage of wordpress. They should have ran into the same problems like i do now.
Hallo
check the Apache server status page in Keyhelp. Maybe the sites are attacked or the Facebook crawler "facebookexternalhit" is crwaling your sites.
aardappel wrote: Mon 1. Jul 2024, 17:21so my question if someone has it running with several users/wordpress installs
More than one server with XXX installations of Joomla!, Wordpress or Typo3
aardappel wrote: Mon 1. Jul 2024, 17:21They should have ran into the same problems like i do now.
No.
