Weird errors after postfix restart
Deam
Post by Deam »
Hello, I have a little concern that something went wrong with postfix after the update. Below I upload the warnings that appear when restarting the service, what should I do in this situation? The files are different. should I replace them with files from second path?
Never had this problem before hence my question. Greetings and I would like to ask for some guidance.
Server operating system + version:
Debian 12.5
Server virtualization technology used:
KeyHelp version + build number:
24.1 (Build 3285)
Problem description / error messages/ Additional information:
2024-07-02 14:52:35 postfix/master daemon started -- version 3.7.11, configuration /etc/postfix
2024-07-02 14:52:35 postfix/postfix-script starting the Postfix mail system
2024-07-02 14:52:35 postfix/postfix-script warning: /var/spool/postfix/lib/x86_64-linux-gnu/libgcc_s.so.1 and /lib/x86_64-linux-gnu/libgcc_s.so.1 differ
2024-07-02 14:52:35 postfix/postfix-script warning: /var/spool/postfix/lib/x86_64-linux-gnu/libnss_systemd.so.2 and /lib/x86_64-linux-gnu/libnss_systemd.so.2 differ
2024-07-02 14:52:35 postfix/postfix-script warning: /var/spool/postfix/etc/ssl/certs/GTS_Root_R3.pem and /etc/ssl/certs/GTS_Root_R3.pem differ
2024-07-02 14:52:35 postfix/postfix-script warning: /var/spool/postfix/etc/ssl/certs/GlobalSign_ECC_Root_CA_-_R4.pem and /etc/ssl/certs/GlobalSign_ECC_Root_CA_-_R4.pem differ
2024-07-02 14:52:35 postfix/postfix-script warning: /var/spool/postfix/etc/ssl/certs/GTS_Root_R2.pem and /etc/ssl/certs/GTS_Root_R2.pem differ
2024-07-02 14:52:35 postfix/postfix-script warning: /var/spool/postfix/etc/ssl/certs/GTS_Root_R1.pem and /etc/ssl/certs/GTS_Root_R1.pem differ
2024-07-02 14:52:35 postfix/postfix-script warning: /var/spool/postfix/etc/ssl/certs/GTS_Root_R4.pem and /etc/ssl/certs/GTS_Root_R4.pem differ
2024-07-02 14:52:35 postfix/postfix-script warning: /var/spool/postfix/etc/hosts and /etc/hosts differ
2024-07-02 14:52:35 postfix/postfix-script warning: /var/spool/postfix/etc/localtime and /etc/localtime differ
2024-07-02 14:52:35 postfix To disable backwards compatibility use "postconf compatibility_level=3.6" and "postfix reload"
Re: Weird errors after postfix restart
Post by Fezzi »
Was there an explanation to this errors?
Is it normal?
Same issue with a suggested solution by me:
ENGLISH: https://community-keyhelp-de.translate. ... app#p53759
GERMAN: viewtopic.php?p=53759#p53759
