Roundcube - Enigma-Plugin  [SOLVED]
bori123
Post by bori123 »
Sicher nicht, habe aber die starke Vermutung
Debian 12.7 (64-bit)
24.2 (Build 3326)
Ich nutze Roundcube als eigenständige Installation. Jetzt wollte ich, bei meiner Mailcow-Installation läuft es, das Enigma Plugin in Roundcube aktivieren und den Mailcow-Server abstellen. Allerdings bekomme ich, sobald ich Enigma in den Plugins installiere einen Serverfehler. Habe auf dem Gerät auch per apt-get install gnupg das entsprechende Paket installiert
es funktioniert
es funktioniert nicht
[03-Oct-2024 19:37:59 Europe/Berlin] PHP Fatal error:  Uncaught Error: Class "enigma_driver_gnupg2" not found in /home/users/bori123/www/roundcube/plugins/enigma/lib/enigma_engine.php:77
Stack trace:
#0 /home/users/bori123/www/roundcube/plugins/enigma/lib/enigma_engine.php(991): enigma_engine->load_pgp_driver()
#1 /home/users/bori123/www/roundcube/plugins/enigma/enigma.php(441): enigma_engine->list_keys()
#2 /home/users/bori123/www/roundcube/program/lib/Roundcube/rcube_plugin_api.php(520): enigma->identity_form()
#3 /home/users/bori123/www/roundcube/program/actions/settings/identity_edit.php(165): rcube_plugin_api->exec_hook()
#4 /home/users/bori123/www/roundcube/program/include/rcmail_output_html.php(1484): rcmail_action_settings_identity_edit::identity_form()
#5 [internal function]: rcmail_output_html->xml_command()
#6 /home/users/bori123/www/roundcube/program/include/rcmail_output_html.php(1322): preg_replace_callback()
#7 /home/users/bori123/www/roundcube/program/include/rcmail_output_html.php(825): rcmail_output_html->parse_xml()
#8 /home/users/bori123/www/roundcube/program/include/rcmail_output_html.php(654): rcmail_output_html->parse()
#9 /home/users/bori123/www/roundcube/program/actions/settings/identity_edit.php(77): rcmail_output_html->send()
#10 /home/users/bori123/www/roundcube/program/include/rcmail.php(282): rcmail_action_settings_identity_edit->run()
#11 /home/users/bori123/www/roundcube/index.php(278): rcmail->action_handler()
#12 {main}
  thrown in /home/users/bori123/www/roundcube/plugins/enigma/lib/enigma_engine.php on line 77
es macht den Anschein als wäre das PHP Plugin nicht mit installiert...
apt list --installed | grep php
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libapache2-mod-php8.2/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php-auth-sasl/stable,now 1.1.0-1 all  [installiert]
php-bcmath/stable,now 2:8.2+93 all  [installiert]
php-common/stable,now 2:93 all  [Installiert,automatisch]
php-curl/stable,now 2:8.2+93 all  [installiert]
php-fpm/stable,now 2:8.2+93 all  [installiert]
php-gd/stable,now 2:8.2+93 all  [installiert]
php-gmp/stable,now 2:8.2+93 all  [installiert]
php-imagick/stable,now 3.7.0-4 amd64  [installiert]
php-intl/stable,now 2:8.2+93 all  [installiert]
php-mail-mime/stable,now 1.10.11-1 all  [installiert]
php-mbstring/stable,now 2:8.2+93 all  [installiert]
php-mysql/stable,now 2:8.2+93 all  [installiert]
php-net-sieve/stable,now 1.4.6-1 all  [installiert]
php-net-smtp/stable,now 1.10.1-1 all  [installiert]
php-net-socket/stable,now 1.2.2-2 all  [installiert]
php-pear/stable,now 1:1.10.13+submodules+notgz+2022032202-2 all  [Installiert,automatisch]
php-pspell/stable,now 2:8.2+93 all  [installiert]
php-readline/stable,now 2:8.2+93 all  [installiert]
php-redis/stable,now 5.3.7+4.3.0-3 amd64  [installiert]
php-soap/stable,now 2:8.2+93 all  [installiert]
php-xml/stable,now 2:8.2+93 all  [Installiert,automatisch]
php-zip/stable,now 2:8.2+93 all  [installiert]
php8.2-bcmath/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-cli/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-common/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-curl/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-fpm/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-gd/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-gmp/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-igbinary/stable,now 3.2.13-1 amd64  [Installiert,automatisch]
php8.2-imagick/stable,now 3.7.0-4 amd64  [Installiert,automatisch]
php8.2-intl/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-mbstring/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-mysql/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-opcache/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-pspell/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-readline/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-redis/stable,now 5.3.7+4.3.0-3 amd64  [Installiert,automatisch]
php8.2-soap/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-xml/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2-zip/stable-security,now 8.2.24-1~deb12u1 amd64  [Installiert,automatisch]
php8.2/stable-security,now 8.2.24-1~deb12u1 all  [Installiert,automatisch]
php/stable,now 2:8.2+93 all  [installiert]
Jetzt möchte ich ungern in die PHP-Version zerlegen, nicht dass ich hinterher irgendwelche Abhängigkeiten von Keyhelp zerlege...
Viele Grüße
Alex
Re: Roundcube - Enigma-Plugin  [SOLVED]
die Klasse scheint eher "enigma_driver_gnupg" statt "enigma_driver_gnupg2" zu heißen.
https://github.com/search?q=repo%3Aroun ... &type=code
Ich sehe hier den Zusammenhang zwischen KeyHelp nicht, da die Fehlermeldung auf ein Problem innerhalb der separaten Roundcube Instanz/dem Plugin hinweist.
bori123
Post by bori123 »
Alexander wrote: Fri 4. Oct 2024, 09:44 Hallo,
vielen Dank für den Schubser... Manchmal sieht man den Wald vor lauter Bäumen nicht... Oder so ähnlich
In der config.inc.php des enigma Plgins stand:
// A driver to use for PGP. Default: "gnupg2".
$config['enigma_pgp_driver'] = 'gnupg2';
Geändert zu
// A driver to use for PGP. Default: "gnupg".
$config['enigma_pgp_driver'] = 'gnupg';
Und es funktioniert... Machmal ist es so einfach.
Wie kann ich das Thema als erledigt markieren?
Viele Grüße
Alex
