Upgrade auf Debian 12: "cannot be decoded by this version of the ionCube Loader"  [SOLVED]
josuedugg
Post by josuedugg »
Hi support, please your help I had an issue during upgrade from debian 11 to 12, basically ssh session frozen when I was installing with the script, thus, I come back to the server and killed the upgrade process and now this is the result when I try to run the script again:
root@cloud:~# php --version
PHP Warning:  PHP Startup: ^(text/|application/xhtml\+xml) (offset=0): unrecognised compile-time option bit(s) in Unknown on line 0
PHP 8.2.24 (cli) (built: Sep 27 2024 04:03:19) (NTS)
Copyright (c) The PHP Group
Zend Engine v4.2.24, Copyright (c) Zend Technologies
    with Zend OPcache v8.2.24, Copyright (c), by Zend Technologies
root@cloud:~# wget --no-check-certificate https://install.keyhelp.de/scripts/keyhelp_debian_upgrade_11_to_12_php82 -O keyhelp_debian_upgrade_11_to_12.php && php keyhelp_debian_upgrade_11_to_12.php
--2024-10-24 19:04:41--  https://install.keyhelp.de/scripts/keyhelp_debian_upgrade_11_to_12_php82
Resolving install.keyhelp.de (install.keyhelp.de)... 62.141.56.232, 2001:1b60:2:11:913:101:be57:cafe
Connecting to install.keyhelp.de (install.keyhelp.de)|62.141.56.232|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 152085 (149K)
Saving to: ‘keyhelp_debian_upgrade_11_to_12.php’
keyhelp_debian_upgrade_11_to_1 100%[=================================================>] 148.52K   386KB/s    in 0.4s
2024-10-24 19:04:43 (386 KB/s) - ‘keyhelp_debian_upgrade_11_to_12.php’ saved [152085/152085]
PHP Parse error:  syntax error, unexpected identifier "ionCube" in /root/keyhelp_debian_upgrade_11_to_12.php on line 5
Is there a way to revert or repair the keyhelp installation (i don't have snapshots/backups of the server). Please your assistance because keyhelp is not working now and my sites are down
Re: Upgrade auf Debian 12: "cannot be decoded by this version of the ionCube Loader"
josuedugg wrote: Fri 25. Oct 2024, 03:08 Is there a way to revert or repair the keyhelp installation (i don't have snapshots/backups of the server). Please your assistance because keyhelp is not working now and my sites are down
Try to enable ioncube and sourceguardian first
phpenmod ioncube;
phpenmod sourceguardian;
then run the upgrade script again.
josuedugg
Post by josuedugg »
It is still failing, now with this error:
root@cloud:~# phpenmod -v 8.2 ioncube
root@cloud:~# phpenmod -v 8.2 sourceguardian
    with the ionCube PHP Loader v13.3.1, Copyright (c) 2002-2024, by ionCube Ltd.
    with SourceGuardian v15.0.2, Copyright (c) 2000-2024, by SourceGuardian Ltd.
root@cloud:~# wget --no-check-certificate https://install.keyhelp.de/scripts/upgrade_operating_system.sh -O upgrade_operating_system.sh && bash upgrade_operating_system.sh
Warning: preg_match(): Compilation failed: unrecognised compile-time option bit(s) at offset 0 in /home/keyhelp/www/keyhelp/core/Utilities/IpAddress.php on line 175
Warning: preg_match(): Compilation failed: unrecognised compile-time option bit(s) at offset 0 in /home/keyhelp/www/keyhelp/core/Utilities/IpAddress.php on line 205
Warning: preg_match(): Compilation failed: unrecognised compile-time option bit(s) at offset 0 in /home/keyhelp/www/keyhelp/core/System/OperatingSystem.php on line 85
Warning: Trying to access array offset on value of type null in /home/keyhelp/www/keyhelp/core/System/OperatingSystem.php on line 86
Fatal error: Uncaught Error: Class "mysqli" not found in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php:75
Stack trace:
#0 /home/keyhelp/www/keyhelp/core/pending/DBConnection.php(65): DBConnection->connect()
#1 /root/keyhelp_debian_upgrade_11_to_12.php(104): DBConnection->__construct()
#2 {main}
  thrown in /home/keyhelp/www/keyhelp/core/pending/DBConnection.php on line 75
First, where did you find this command?
The above is outdated (thou does still work), this is the newer version:
This might indicate, that the libraries on your systems may be messed up.
So first lets use some simple systems command and see if it can fix it.
apt update
apt upgrade
apt dist-upgrade
apt autoremove
apt clean
Please report all errors.
By the way the simplest and cleanest solution would be, to rollback a backup you made before dist-upgrade.
josuedugg
Post by josuedugg »
After applying the shared commands and rebooting the node this is the result:
--2024-10-28 17:25:48--  https://install.keyhelp.de/scripts/upgrade_operating_system.sh
Length: 10073 (9.8K) [text/x-sh]
Saving to: ‘upgrade_operating_system.sh’
upgrade_operating_system.sh    100%[=================================================>]   9.84K  --.-KB/s    in 0s
2024-10-28 17:25:49 (113 MB/s) - ‘upgrade_operating_system.sh’ saved [10073/10073]
You are about to upgrade the operating system of your KeyHelp server.
Running system checks...
Run upgrade script...
WARNING: Module ioncube ini file doesn't exist under /etc/php/8.3/mods-available
Stack trace:
#2 {main}
josuedugg
Re: Upgrade auf Debian 12: "cannot be decoded by this version of the ionCube Loader"  [SOLVED]
Post by josuedugg »
Finally update was successfully solved by performing the following:
apt update
apt upgrade
apt dist-upgrade
apt autoremove
apt clean
apt install php8.2-mysqli
phpenmod -v 8.2 mysqli
systemctl restart apache2
systemctl restart php8.2-fpm
--2024-10-28 18:31:05--  https://install.keyhelp.de/scripts/upgrade_operating_system.sh
upgrade_operating_system.sh        100%[==============================================================>]   9.84K  --.-KB/s    in 0s
2024-10-28 18:31:06 (118 MB/s) - ‘upgrade_operating_system.sh’ saved [10073/10073]
ERROR: No upgrade available.
Many thanks for the assistance Support Team
Great and prompt support!
