Webspace  [SOLVED]
fatontonni123
Webspace
Post by fatontonni123 »
Webspace Dont work can you help mu.. 0 B
Re: Webspace
Have a look at the german section
viewtopic.php?t=13439&start=15
fatontonni123
Re: Webspace
Yes but dont work to install linux-image-extra-virtual
unable to locate package linux-modules-extra-virtual
Re: Webspace
First try
repquota -a
and post output here
fatontonni123
Re: Webspace
repquota -a
*** Report for user quotas on device /dev/sda1
Block grace time: 7days; Inode grace time: 7days
                        Block limits                File limits
User            used    soft    hard  grace    used  soft  hard  grace
root      -- 3966360       0       0          55549     0     0
man       --    1372       0       0            118     0     0
www-data  --    2208       0       0             59     0     0
_apt      --      12       0       0              3     0     0
systemd-timesync --       4       0       0              2     0     0
keyhelp   --  179300       0       0          13947     0     0
bind      --      12       0       0              3     0     0
mysql     --  460872       0       0            928     0     0
ftp       --       4       0       0              1     0     0
postfix   --      80       0       0             53     0     0
vmail     --     208       0       0             45     0     0
_rspamd   --   53560       0       0            259     0     0
redis     --     152       0       0              6     0     0
clamav    --  367100       0       0              9     0     0
anarecruitment --  319892  512000  512000          14377 64000 64000
dpsweb    --  169700 1048576 1048576           9745 174762 174762
mhtechnik --  246332  512000  512000          10099 64000 64000
swissfootballfuture --  270600  512000  512000           9443 64000 64000
mhtechni  --  162176  512000  512000           7727 64000 64000
holzgroup --  880388 1433600 1433600          17294 179200 179200
gmsc      --  432048 1048576 1048576          24055 131072 131072
gazeta    -- 3373436 12582912 12582912          53192 1572864 1572864
#3064     --   17884       0       0            339     0     0
#5009     ++  349188   51200   51200  6days   11298  6400  6400  6days
Re: Webspace
Now try this
service quota stop
quotacheck -avmugf
service quota start
fatontonni123
Re: Webspace
root@v1736101981:~# service quota stop
root@v1736101981:~# quotacheck -avmugf
quotacheck: Your kernel probably supports ext4 quota feature but you are using external quota files. Please switch your filesystem to use ext4 quota feature as
external quota files on ext4 are deprecated.
quotacheck: Scanning /dev/sda1 [/] done
quotacheck: Checked 21504 directories and 235630 files
root@v1736101981:~# service quota start
root@v1736101981:~#
See i have make this code
Re: Webspace
the output is normal and OK
fatontonni123
Re: Webspace
Yes but Web space dont work is 0 Bytes and not calculate storage .
Re: Webspace
do the files in the folder belong to the correct user?
fatontonni123
Re: Webspace
Yes in all users this dont work.. I have create a new user but stil is same.. i upload a file but workspace dont work is 0B
Re: Webspace
Logins via PM please
fatontonni123
Re: Webspace
Okay i have Write.
Re: Webspace
yes, but without logins
Re: Webspace  [SOLVED]
I have checked your server:
quotatool: Quotatool cannot function while quotas are disabled. Please enable quotas by running `quotaon -a`.
So i enabled quota with the command:
quotaon -a
and triggert disk space calculation.
Now it is working.
