Installationsproblem | Database Error  [GELÖST]
meganischu
Post by meganischu »
Guten Tag,
folgendes habe ich als Fehler angezeigt bekommen, als ich KeyHelp auf meinem VServer installieren wollte:
Installation wird durchgeführt:
Update sources list ................................................ OKAY
Installation requirements .......................................... OKAY
Sudo ............................................................... OKAY
Bind9 .............................................................. OKAY
SSL/TLS ............................................................ OKAY
PHP ................................................................ OKAY
Apache web server .................................................. OKAY
PHP-FPM ............................................................ OKAY
MariaDB ........................................................... ERROR
KeyHelp
Warning: Database error: SQLSTATE[HY000] [2002] Connection refused in /home/keyhelp/www/keyhelp/core/Database/DatabaseConnection.php on line 510
Fatal error: Uncaught Error: Call to a member function prepare() on null in /home/keyhelp/www/keyhelp/core/Database/DatabaseConnection.php:264
Stack trace:
#0 /home/keyhelp/www/keyhelp/core/Database/DatabaseConnection.php(354): Database\DatabaseConnection->query()
#1 /home/keyhelp/www/keyhelp/core/Database/DatabaseConnection.php(624): Database\DatabaseConnection->fetchColumn()
#2 /home/keyhelp/www/keyhelp/core/Database/DatabaseConnection.php(181): Database\DatabaseConnection->loadServerInformation()
#3 /home/keyhelp/www/keyhelp/core/Install/KeyHelpInstaller.php(386): Database\DatabaseConnection->__construct()
#4 /home/keyhelp/www/keyhelp/core/Install/KeyHelpInstaller.php(267): Install\KeyHelpInstaller->databaseOperation()
#5 /home/keyhelp/www/keyhelp/install/install.php(841): Install\KeyHelpInstaller->installComponent()
#6 {main}
thrown in /home/keyhelp/www/keyhelp/core/Database/DatabaseConnection.php on line 264
root@v29364:~#
Ich bitte um hilfe dieses Problem zu lösen
Debian 12 (Minimal) - Neuste KeyHelp Version
Liebe Grüße
Re: Installationsproblem | Database Error  [GELÖST]
