Nur Apache Default Site
Simmi
Post by Simmi »
Ich bin sicher, dass die Ursache des Problems bei KeyHelp liegt Ja
Server-Betriebssystem + Version Ubuntu 20.04.6 LTS (GNU/Linux 5.4.0-216-generic x86_64)
Eingesetzte Server-Virtualisierung-Technologie KVM
KeyHelp-Version + Build-Nummer 25.0 (Build 3398)
Problembeschreibung / Fehlermeldungen Apache Default Site auf jeder Domain und auich NoSSL
Erwartetes Ergebnis Anzeigen der Website / des Panels
Tatsächliches Ergebnis Ubuntu Apache2 default site
Re: Nur Apache Default Site
Welche Änderungen wurden am System vorgenommen?
Simmi
Post by Simmi »
Das iost eine sehr gute Frage, die ich selbst nicht beantworten kann...
poste den Inhalt Deiner /etc/apache2/apache2.conf
Simmi
Post by Simmi »
# This is the main Apache server configuration file. It contains the
# configuration directives that give the server its instructions.
# See http://httpd.apache.org/docs/2.4/ for detailed information about
# the directives and /usr/share/doc/apache2/README.Debian about Debian specific
# hints.
# Summary of how the Apache 2 configuration works in Debian:
# The Apache 2 web server configuration in Debian is quite different to
# upstream's suggested way to configure the web server. This is because Debian's
# default Apache2 installation attempts to make adding and removing modules,
# virtual hosts, and extra configuration directives as flexible as possible, in
# order to make automating the changes and administering the server as easy as
# possible.
# It is split into several files forming the configuration hierarchy outlined
# below, all located in the /etc/apache2/ directory:
# /etc/apache2/
# |-- apache2.conf
# | `-- ports.conf
# |-- mods-enabled
# | |-- *.load
# | `-- *.conf
# |-- conf-enabled
# | `-- *.conf
# `-- sites-enabled
# `-- *.conf
# * apache2.conf is the main configuration file (this file). It puts the pieces
# together by including all remaining configuration files when starting up the
# web server.
# * ports.conf is always included from the main configuration file. It is
# supposed to determine listening ports for incoming connections which can be
# customized anytime.
# * Configuration files in the mods-enabled/, conf-enabled/ and sites-enabled/
# directories contain particular configuration snippets which manage modules,
# global configuration fragments, or virtual host configurations,
# respectively.
# They are activated by symlinking available configuration files from their
# respective *-available/ counterparts. These should be managed by using our
# helpers a2enmod/a2dismod, a2ensite/a2dissite and a2enconf/a2disconf. See
# their respective man pages for detailed information.
# * The binary is called apache2. Due to the use of environment variables, in
# the default configuration, apache2 needs to be started/stopped with
# /etc/init.d/apache2 or apache2ctl. Calling /usr/bin/apache2 directly will not
# work with the default configuration.
# Global configuration
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the Mutex documentation (available
# at <URL:http://httpd.apache.org/docs/2.4/mod/core.html#mutex>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
#ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
#Mutex file:${APACHE_LOCK_DIR} default
# The directory where shm and other runtime files will be stored.
DefaultRuntimeDir ${APACHE_RUN_DIR}
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 5
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a <VirtualHost>
# container, error messages relating to that virtual host will be
# logged here. If you *do* define an error logfile for a <VirtualHost>
# container, that host's errors will be logged there and not here.
ErrorLog ${APACHE_LOG_DIR}/error.log
# LogLevel: Control the severity of messages logged to the error_log.
# Available values: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the log level for particular modules, e.g.
# "LogLevel info ssl:warn"
LogLevel warn
# Include module configuration:
IncludeOptional mods-enabled/*.load
IncludeOptional mods-enabled/*.conf
# Include list of ports to listen on
Include ports.conf
# Sets the default security model of the Apache2 HTTPD server. It does
# not allow access to the root filesystem outside of /usr/share and /var/www.
# The former is used by web applications packaged in Debian,
# the latter may be used for local directories served by the web server. If
# your system is serving content from a sub-directory in /srv you must allow
# access here, or in any related virtual host.
<Directory />
Options FollowSymLinks
AllowOverride None
Require all denied
</Directory>
<Directory /usr/share>
AllowOverride None
Require all granted
</Directory>
<Directory /var/www/>
Options Indexes FollowSymLinks
AllowOverride None
Require all granted
</Directory>
#<Directory /srv/>
# Options Indexes FollowSymLinks
# AllowOverride None
# Require all granted
#</Directory>
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives. See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<FilesMatch "^\.ht">
Require all denied
</FilesMatch>
# The following directives define some format nicknames for use with
# a CustomLog directive.
# These deviate from the Common Log Format definitions in that they use %O
# (the actual bytes sent including headers) instead of %b (the size of the
# requested file), because the latter makes it impossible to detect partial
# requests.
# Note that the use of %{X-Forwarded-For}i instead of %h is not recommended.
# Use mod_remoteip instead.
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Include of directories ignores editors' and dpkg's backup files,
# see README.Debian for details.
# Include generic snippets of statements
IncludeOptional conf-enabled/*.conf
# Include the virtual host configurations:
IncludeOptional sites-enabled/*.conf
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
#Include KeyHelp vHosts
Include keyhelp/keyhelp.conf
ist im Ordner sites-enabled eine Konfiguration drin?
Simmi
Post by Simmi »
root@hosting /etc/apache2/sites-available # ls
000-default.conf  default-ssl.conf
Die default.conf beinhaltet:
<VirtualHost *:80>
        # The ServerName directive sets the request scheme, hostname and port that
        # the server uses to identify itself. This is used when creating
        # redirection URLs. In the context of virtual hosts, the ServerName
        # specifies what hostname must appear in the request's Host: header to
        # match this virtual host. For the default virtual host (this file) this
        # value is not decisive as it is used as a last resort host regardless.
        # However, you must set it for any further virtual host explicitly.
        #ServerName www.example.com
        ServerAdmin webmaster@localhost
        DocumentRoot /var/www/html
        # Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
        # It is also possible to configure the loglevel for particular
        # modules, e.g.
        #LogLevel info ssl:warn
        CustomLog ${APACHE_LOG_DIR}/access.log combined
        # For most configuration files from conf-available/, which are
        # enabled or disabled at a global level, it is possible to
        # include a line for only one particular virtual host. For example the
        # following line enables the CGI configuration for this host only
        # after it has been globally disabled with "a2disconf".
        #Include conf-available/serve-cgi-bin.conf
</VirtualHost>
Die Frage war nach sites-enabled
Simmi
Post by Simmi »
Ohh, moment
Simmi
Post by Simmi »
Florian wrote: Thu 12. Jun 2025, 12:44 Die Frage war nach sites-enabled
Den Ordner gibt es irgendwie net
Wahrscheinlich daher der Default, weil keine config da
schick mir mal den Login via PM
Simmi
Post by Simmi »
Den SSH meinst du?
Simmi
Post by Simmi »
Florian wrote: Thu 12. Jun 2025, 12:51 Hallo,
Hab geschickt, kannst du mich hier auf dem laufenden halten im Thread?
die Ursache kurz und prägnant:
]# dpkg --list | grep nginx
ii  libnginx-mod-http-image-filter        1.18.0-0ubuntu1.7                                         amd64        HTTP image filter module for Nginx
ii  libnginx-mod-http-xslt-filter         1.18.0-0ubuntu1.7                                         amd64        XSLT Transformation module for Nginx
ii  libnginx-mod-mail                     1.18.0-0ubuntu1.7                                         amd64        Mail module for Nginx
ii  libnginx-mod-stream                   1.18.0-0ubuntu1.7                                         amd64        Stream module for Nginx
ii  nginx                                 1.18.0-0ubuntu1.7                                         all          small, powerful, scalable web/proxy server
ii  nginx-common                          1.18.0-0ubuntu1.7                                         all          small, powerful, scalable web/proxy server - common files
ii  nginx-core                            1.18.0-0ubuntu1.7                                         amd64        nginx web/proxy server (standard version)
ss -tulpen | grep :443
tcp    LISTEN  0       511                                        0.0.0.0:443                                        0.0.0.0:*                                   users:(("nginx",pid=693,fd=9),("nginx",pid=692,fd=9),("nginx",pid=691,fd=9),("nginx",pid=690,fd=9),("nginx",pid=689,fd=9)) ino:24582 sk:c1 <->
ss -tulpen | grep :80
tcp    LISTEN  0       511                                        0.0.0.0:80                                         0.0.0.0:*                                   users:(("nginx",pid=693,fd=6),("nginx",pid=692,fd=6),("nginx",pid=691,fd=6),("nginx",pid=690,fd=6),("nginx",pid=689,fd=6)) ino:24579 sk:6a <->
Simmi
Post by Simmi »
Florian wrote: Thu 12. Jun 2025, 15:29 Hallo,
das heißt?
mehrfache Portbelegung?
