Error: no SASL authentication mechanisms  [SOLVED]
technotravel
Post by technotravel »
not really sure actually
Debian 13.0 (64-bit)
(e.g. none, OpenVZ, KVM, XEN, etc.)
KVM (server is ARM)
25.2 (Build 3483)
Clients can't log in to email anymore, and mails can't be sent or received
Expected result
Clients can log in and receive and send mails
Actual result
see details below
Steps to reproduce
collect mail from a client (TB or FairEmail), try to log in webmail, send a mail from a client
Additional information
(e.g. recent changes to the server, excerpts from log files (/var/log/*, /var/log/keyhelp/php-error.log, etc.))
I have the suspicion it happened after a recent upgrade (dist-upgrade), but not sure. As mentioned, server is running on ARM.
some console messages showing in journalctl -f
Aug 24 10:55:42 tembo.meinevserver.de postfix/smtpd[66120]: warning: SASL: Connect to Dovecot auth socket 'private/auth' failed: Connection refused
Aug 24 10:55:42 tembo.meinevserver.de postfix/smtpd[66120]: fatal: no SASL authentication mechanisms
Aug 24 10:55:43 tembo.meinevserver.de postfix/master[1487]: warning: process /usr/lib/postfix/sbin/smtpd pid 66120 exit status 1
Aug 24 10:55:43 tembo.meinevserver.de postfix/master[1487]: warning: /usr/lib/postfix/sbin/smtpd: bad command startup -- throttling
when trying webmail login:
Aug 24 11:00:43 tembo.meinevserver.de roundcube[78591]: PHP Warning:  stream_socket_client(): Unable to connect to 127.0.0.1:143 (Verbindungsaufbau abgelehnt) in /home/keyhelp/www/roundcube/program/lib/Roundcube/rcube_imap_generic.php on line 1059
Aug 24 11:00:43 tembo.meinevserver.de roundcube[78591]: <7ocuhlgb> IMAP Error: Login failed for redacted@mymail.com against 127.0.0.1 from 2003:ef:7707:bd00:75ee:48d2:b02f:84eb. Could not connect to 127.0.0.1:143: Verbindungsaufbau abgelehnt in /home/keyhelp/www/roundcube/program/lib/Roundcube/rcube_imap.php on line 211 (POST /webmail/?_task=login&_action=login)
Aug 24 11:00:55 tembo.meinevserver.de sudo[79897]:  keyhelp : PWD=/home/keyhelp/www/keyhelp ; USER=root ; COMMAND=/
Please help!
technotravel
Re: Error: no SASL authentication mechanisms
Kann meinen Beitrag nicht mehr bearbeiten - hier noch eine Meldung:
Aug 24 14:45:04 tembo.meinevserver.de postfix/smtpd[184442]: connect from unknown[191.232.166.181]
Aug 24 14:45:05 tembo.meinevserver.de postfix/smtpd[184442]: warning: SASL: Connect to Dovecot auth socket 'private/auth' failed: Connection refused
Aug 24 14:45:05 tembo.meinevserver.de postfix/smtpd[184442]: fatal: no SASL authentication mechanisms
Aug 24 14:45:06 tembo.meinevserver.de postfix/master[1487]: warning: process /usr/lib/postfix/sbin/smtpd pid 184442 exit status 1
Aug 24 14:45:06 tembo.meinevserver.de postfix/master[1487]: warning: /usr/lib/postfix/sbin/smtpd: bad command startup -- throttling
Hat jemand eine Idee, woran das liegen könnte?
Post by Fezzi »
Ohne das genauer untersucht zu haben... laeuft Dein "Dovecot" ... schon mal den Dienst neu gestartet?
Edit: Oh, I just realized that you were posting in the englisch section...
On a first quick look it looks like a "Dovecot" malfunction... did you try to restart the service already?
technotravel
Re: Error: no SASL authentication mechanisms  [SOLVED]
Hi Fezzi,
sorry - weil die Vorlage auf Englisch ist, habe ich es halt automatisch auf Englisch geschrieben :mrgreen:
Danke für den Tip mit Dovecot, das Problem ist eindeutig dort. Hatte den Sever schon rebooted, hat nichts gebracht.
Ist mir jetzt aber zu blöd, zu versuchen, das zu richten - ich habe beschlossen, dass ich diesen ARM Server doch lieber loswerden will. Warte nur auf eine günstige Gelegenheit :mrgreen:
Post by Fezzi »
technotravel wrote: Mon 25. Aug 2025, 14:50 Hi Fezzi,
Die Vorlage war auf Englisch weil Du in der Englischen Version des Forums gepostet hast... ;) :)
Screenshot from 2025-08-26 07-57-18.png (3.55 KiB) Viewed 19265 times
Guenstige Gelegenheiten fuer einen anderen Server sollten sich ende des Monats einstellen wenn Du da suchst wo ich vermute... :mrgreen:
technotravel
Fezzi wrote: Tue 26. Aug 2025, 03:00
Muss wohl recht nervös gewesen sein wg diesem Dovecot Kack :mrgreen:
Fezzi wrote: Tue 26. Aug 2025, 03:00 Guenstige Gelegenheiten fuer einen anderen Server sollten sich ende des Monats einstellen wenn Du da suchst wo ich vermute... :mrgreen:
Genau - und schon erletscht! :D
Hätte da jetzt einen ARM-Server Special abzugeben ...
