How to change Hostname SSL
sunday532
Post by sunday532 »
Hello everyone,
I’m currently running KeyHelp on my Ubuntu 24 with keyhelp version 25.2 (Build 3483) and I’d like to replace the SSL certificate used by the KeyHelp panel itself (hostname).
I have already generated an Origin SSL certificate from Cloudflare.
I only see the global Let's Encrypt settings — there is no option to manually upload or change the SSL certificate for the panel hostname.
Because i want to change Ssl Cloudflare to Full Strict.
Could someone please explain how to manually replace or install a custom SSL certificate for the KeyHelp panel hostname?
Thank you in advance!
Re: How to change Hostname SSL
you have got the option "secure server services" in the menu SSL certificates.
There you can choose either to use Let's Enxpryt or to use your own certificate that has been added before via "Add SSL/TLS certificate".
