CPU Load [SOLVED]
fatontonni123
CPU Load [SOLVED]
The CPU process continues to be very high.
Can you help my..
Re: CPU Load
Run
htopIf not already installed, apt install htop, or if on Ubuntu sudo apt install htop.
BTW: That is far from critical, if you have severe problems, e.g. crawlers flooding your sites, the load average goes much beyond 50.
Re: CPU Load
The post template that is provided when creating a new thread in the "Bugs and Issues" forum section exists for a reason.
Moved to Off Topic
fatontonni123
Re: CPU Load
24unix wrote: ↑Thu 20. Nov 2025, 18:14 You need first to find out what causes the hight load.
Run.Code: Select all
htop
bash: htop: command not foundRe: CPU Load
fatontonni123
