Problems activating SSL
tiagoinacio
Debian 13.3 (64-bit)
25.3 (Build 3569)
I'm having problems activating SSL, I have several domains working without problems but there is 1 domain that doesn't work, I've done several tests and it always gives an error when I activate https.
/etc/ssl/keyhelp/letsencrypt/user/
Thanks
Kind Regards
- technotravel
- KeyHelp Translator
Re: Problems activating SSL
Check that these settings are correct for the domain in question ... also for IPv6
And what does the error message say?
