whmcs api problem
- saviorhost
whmcs api problem
I think I encountered a problem while troubleshooting the SSL issue. I'm getting the following error directly from the API system. I think it's an IP ban. But even after deleting all IPs using fail2ban, I'm still getting the same error.
Erro ao gerar URL de login: cURL Error: Operation timed out after 30002 milliseconds with 0 bytes received
- saviorhost
Re: whmcs api problem
I'm getting this error now. I can't seem to activate the WHMCS module.
- saviorhost
