Update SO Debian 13 Error
PuntonetSvb
Re: Update SO Debian 13 Error
I had the same error yesterday. I was includingPuntonetSvb wrote: ↑Fri 6. Mar 2026, 13:00 Initially, I got a Bind error, but everything else seemed to be working correctly.
/etc/bind/named.conf.default-zones
which has been removed from Trixie.
PuntonetSvb
And how did you solve it? I've been trying for two days straight and there's no way.24unix wrote: ↑Fri 6. Mar 2026, 13:08I had the same error yesterday. I was includingPuntonetSvb wrote: ↑Fri 6. Mar 2026, 13:00 Initially, I got a Bind error, but everything else seemed to be working correctly.
So what is the latest state of your server? When you id a rollback and it is not wokring than something is wrong with your backup
Run named-checkconf, it tells you the problematic file.PuntonetSvb wrote: ↑Fri 6. Mar 2026, 16:40And how did you solve it? I've been trying for two days straight and there's no way.24unix wrote: ↑Fri 6. Mar 2026, 13:08I had the same error yesterday. I was includingPuntonetSvb wrote: ↑Fri 6. Mar 2026, 13:00 Initially, I got a Bind error, but everything else seemed to be working correctly.
Remove the entry, restart bind.
It can handle root zones out of the box.
