Meine Remotebackups funktionieren seit Anfangs Dezember nicht mehr. Ich mache verschiedene Backups auf verschiedene Server per FTPS. Dabei kommt es zu folgender Fehlermeldung:
[08-Dec-2018 05:00:02] DEBUG --> start backup process, task id: "84"
[08-Dec-2018 05:00:02] DEBUG --> prepare processing dir
[08-Dec-2018 05:00:02] DEBUG --> deleteDirectory(): the directory "/backup/processing/task-84/" does not exists
[08-Dec-2018 05:00:02] DEBUG --> write pid file
[08-Dec-2018 05:00:02] DEBUG --> check remote connection
[08-Dec-2018 05:00:03] DEBUG --> connection attempt 1/3 failed.
[08-Dec-2018 05:00:03] DEBUG --> sleeping...
[08-Dec-2018 05:01:03] DEBUG --> connection attempt 2/3 failed.
[08-Dec-2018 05:01:03] DEBUG --> sleeping...
[08-Dec-2018 05:02:04] DEBUG --> connection attempt 3/3 failed.
[08-Dec-2018 05:02:04] ERROR --> canceled backup process: Remote server error: Directory is not writable, cannot write test file.
[08-Dec-2018 05:02:04] INFO --> deleteDirectory(): perform rm -rf /backup/processing/task-84/Code: Select all
ftp -z ssl xxx.comGrüsse MIchi
