Hello
how can active Swap usage .. i have 8 G.B Ram ?
Enable Swap usage [SOLVED]
Re: Enable Swap usage
what do you mean? Swap will be used automatically if necessary (as far as you have created a swap partition)
i already have swap partition but always show zero ( Used: 0 B ) ? don't move
Pls post the output of "top"
if no qualified comment is been posted , i assume it is another bot
Wer meint, Kompetenz sei teuer, möge es einmal mit Inkompetenz versuchen. Zitat: Bernd W. Klöckner.
Re: Enable Swap usage [SOLVED]
the system uses swap only when needed. So if it stays around 0 Byte usage, there is still enough RAM free.
