Hatte heute mehrere Mails von Kunden das sie sich nicht einloggen können wegen einer "Wartung"
Hatte eben im Log das Gefunden:
Das geht seit 2 Tagen laut Log so weiter...[07-May-2019 02:00:03] DEBUG --> now waiting for 109 seconds until conntecting to update server!
[07-May-2019 02:01:52] DEBUG --> maintenance log okay
[07-May-2019 02:01:52] DEBUG --> trying to connect to updateserver
[07-May-2019 02:01:53] DEBUG --> set correct tmp-directories mount for update
[07-May-2019 02:01:53] INFO --> new version detected - starting update process from "19.0.1" to "19.1"
[07-May-2019 02:01:53] INFO --> first update step: "19.1" | total steps to reach latest version: 1
[07-May-2019 02:01:53] DEBUG --> create folder for panelupdate "/home/keyhelp/www/keyhelp_tmp/"
[07-May-2019 02:01:53] DEBUG --> start download of "https://install.keyhelp.de/files/releas ... hp7.tar.gz"
[07-May-2019 02:01:54] DEBUG --> file saved to "/home/keyhelp/www/keyhelp_tmp/19.1.tar.gz"
[07-May-2019 02:01:54] DEBUG --> checksum check successful
[07-May-2019 02:01:54] DEBUG --> lock panel
[07-May-2019 02:01:54] DEBUG --> log out all users
[07-May-2019 02:01:54] DEBUG --> run --force-update one last time before new files and db structure may change things
[07-May-2019 02:01:57] DEBUG --> checking running maintenance intervals ...
[07-May-2019 02:01:57] DEBUG --> cronjob "repo-update" still running
[07-May-2019 02:01:57] DEBUG --> sleeping till next check...
[07-May-2019 02:02:27] DEBUG --> cronjob "repo-update" still running
[07-May-2019 02:02:27] DEBUG --> sleeping till next check...
[07-May-2019 02:02:57] DEBUG --> cronjob "repo-update" still running
[07-May-2019 02:02:57] DEBUG --> sleeping till next check...
[07-May-2019 02:03:27] DEBUG --> cronjob "repo-update" still running
[07-May-2019 02:03:27] DEBUG --> sleeping till next check...
[07-May-2019 02:03:57] DEBUG --> cronjob "repo-update" still running
[07-May-2019 02:03:57] DEBUG --> sleeping till next check...
[07-May-2019 02:04:27] DEBUG --> cronjob "repo-update" still running
Bevor ich einfach Reboote frag ich lieber hier nach - nicht das dann gar nix mehr geht
mfg Fiesi
