WordPress "one click install"  [SOLVED]
tom83
Post by tom83 »
WordPress "one click install" feature would be really nice, as well as some other popular scripts (like Joomla, OpenCart)
Re: WordPress "one click install"
You can already do it. It is a bit hidden i admit, but this will change in an upcoming update and makes it more prominent and adds functionallty.
/etc/keyhelp/skel/README:
Here you can define any number of skeleton templates, which then can be selected in KeyHelp
- when creating a new user
- when assigning a new domain to a new, non-existent folder
In the process of creating the user / domain, the skeleton template is then copied to the corresponding target directory.
To create your own skel template, create a subfolder in this directory ("/etc/keyhelp/skel/").
For example "/etc/keyhelp/skel/Wordpress".
The name of the folder determines how it appears in the corresponding selection menus in KeyHelp.
Paste all the files you want to copy when you select the template into this folder.
If the subfolder is preceded by an underscore "_":
For example "/etc/keyhelp/skel/_Wordpress".
This means that this template is only visible to administrators (when creating a new user / creating or editing domain). Users cannot select this template.
Without the prefixed underscore, the template can be selected by both administrators and users.
The directory ".processing" is just for internal purpose, and can be ignored.
tom83
Post by tom83 »
So do you think in the next October release will have "one click install" for WordPress?
That would be awesome. ;)
it is not scheduled for the October update but work on this feature will start right after the next update.
v3ng
Post by v3ng »
Awesome!
I hope that it will also work on existing domains/ folders.
So it can overwrite a current existing directory
v3ng wrote: ↑Wed 25. Sep 2019, 02:07 I hope that it will also work on existing domains/ folders.
You guessed correctly ;).
marcus198514
Post by marcus198514 »
Hallo , gibt es dazu schon eine Info wann das ganze ca. verfügbar ist ?
MOD-EDIT Translation: "Hello, is there already an info when the thing is available ?"
Re: WordPress "one click install"  [SOLVED]
This feature is planed with the next update. I can not tell you any ETA right now. Expect something around December or January.
(Note: No German within the English community area please ;). )
tom83
Post by tom83 »
Sounds good.
obaviet
Re: WordPress "một cú nhấp chuột cài đặt"
Post by obaviet »
Haven't seen it yet
Until KeyHelp 20.2, it can only bei used by customers of the Keyweb AG (https://www.keyweb.de).
With the next update, there will be an opportunity for non-Keyweb customers to us that feature.
obaviet
Post by obaviet »
Alexander wrote: ↑Sat 17. Oct 2020, 15:48 Until KeyHelp 20.2, it can only bei used by customers of the Keyweb AG (https://www.keyweb.de).
Unfortunately you don't have a server in Asia. If so, I will use it. Asia is the fastest growing region in the world, unfortunately you haven't come yet
nboy
Post by nboy »
I have a test install with keyhelp 20.3
Could you please tell me where I can find WordPress "one click install" within the control panel?
at the moment you only can use this feature as Keyweb costumer.
tom83
Post by tom83 »
We are waiting for this great feature. :D
