changing terminal php version
seenu
Post by seenu »
how do i change terminal php version?
since i use composer, my project requires php 7.2, eventhough i set php version to 7.2, when it tries to install composer packages, it is using default php version (which is 7.0) so it is failing.
thanks
Re: changing terminal php version
You can address the required PHP directly:
e.g.
/opt/keyhelp/php/7.2/bin/php
followed by your command to run over it.
I think Alexander has also created another solution for this.
However, I'm just not sure or I can not find the intended post.
Greeting Olli
stfn116
Post by stfn116 »
OlliTheDarkness wrote: Tue 26. Nov 2019, 01:08
Greeting Olli
I think you were searching for this:
keyhelp-php73
keyhelp-php72
keyhelp-php71
PHP-FPM accessible via:
keyhelp-php73-fpm
keyhelp-php72-fpm
keyhelp-php71-fpm
ruediger00
Post by ruediger00 »
I'm running into the same problem. "keyhelp-php73" works fine, but after I get some problem with include paths. Any solutions?
www@kmXXX:/home/users/www/www/site$ keyhelp-php73 /usr/bin/composer install
PHP Warning:  require(Composer/autoload.php): failed to open stream: No such file or directory in /usr/bin/composer on line 8
PHP Fatal error:  require(): Failed opening required 'Composer/autoload.php' (include_path='.:/opt/keyhelp/php/7.3/lib/php') in /usr/bin/composer on line 8
