Video - FFMPEG/FFPROBE
smied
Post by smied »
CentOS (VestaCP)
yum -y install epel-release
rpm --import http://li.nux.ro/download/nux/RPM-GPG-KEY-nux.ro
rpm -Uvh http://li.nux.ro/download/nux/dextop/el ... noarch.rpm
yum update
yum -y install ffmpeg ffmpeg-devel
Ubuntu (KeyHelp)
apt-get install ffmpeg
In the first case, video support appeared immediately on my site, and in the second case, nothing changed
What needs to be done to activate FFMPEG / FFPROBE?
Re: Video - FFMPEG/FFPROBE
have you compared the PHP settings on both servers? What about open_basedir? maybe you must allow access to /usr/bin so that your softare can run the binaries inside this folder
smied
Post by smied »
The settings are standard (did not change anything).
Can you tell me how to provide access to /usr/bin?
There is nothing about this in KeyHelp settings.
Only ##DOCROOT##/www:##DOCROOT##/files:##DOCROOT##/tmp
