Backup password  [SOLVED]
smied
Backup password
Post by smied »
The backup I created requires a password.
Password did not create. :D
This happens if you do not specify a mail for notifications.
nikko
Re: Backup password
Post by nikko »
Ok. And now?
Re: Backup password
If I understand you correctly you wanted to set a password for a backup, but the backup created could be extracted without password - is this correct?
1) Are you sure it is without a password? You can view the content without password, but for extraction you will need the password. Have you tried to extract files - This is normally the point, where you would get asked for a password.
2) Please provide the steps to reproduce this issue, because I am unable to reproduce it on my systems.
Thanks.
smied
Re: Backup password
Post by smied »
1. I create a copy without a password and without mail for notifications
2. Archive requires a password
If I specify a mail for notifications, the archive opens
Re: Backup password  [SOLVED]
I am sorry, but i cannot reproduce this.
I guess your browser goes wild on auto-fill-out the form fields.
