copy DKIM  [SOLVED]
tom83
copy DKIM
Post by tom83 »
What's the trick to copy DKIM and insert into CloudFlare correctly? If I just copy and paste it shows error.
For example , this DKIM, what do I have to take it out to make this work?
default._domainkey IN TXT ( "v=DKIM1; h=sha256; k=rsa; s=email; " "p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAvqNzd88gn0oEnsWMsGhD6zUybV4/wYV1H8rS0Mx4V1sPNf6yJImvOrc0mysZvYnpM9Jlb02udjKGu3kl6VE26tUaxdvQ1bMhaQVKYV0BHriARxq6goQ/yJ5vTsmraJ6f0iNtosHcZ5MoyL1E84nNS0bVZSh+f3qcahuTtT6jYTXtCvG4Bc16TV4GY4lJ3W2BQaDrL7kGYRB3K3" "Nlo4O9xCPWJOESVtccVL4KqK0jf2v7rJjJ4LnZWkkW6Ww5rAIGprV1P9Rk/z82PalMuNIvmUDCGp8OAVWNhOUTUc3WAIvXv2iUXww2Pv8Nml+fI/fZ7+mliKae5EytLGBJzSZ6cwIDAQAB" )
Would be right just copy this below?
nikko
Re: copy DKIM  [SOLVED]
Post by nikko »
Try it so:
   v=DKIM1; h=sha256; k=rsa; s=email; " "p=MIIBIjANBgkqhkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAvqNzd88gn0oEnsWMsGhD6zUybV4/wYV1H8rS0Mx4V1sPNf6yJImvOrc0mysZvYnpM9Jlb02udjKGu3kl6VE26tUaxdvQ1bMhaQVKYV0BHriARxq6goQ/yJ5vTsmraJ6f0iNtosHcZ5MoyL1E84nNS0bVZSh+f3qcahuTtT6jYTXtCvG4Bc16TV4GY4lJ3W2BQaDrL7kGYRB3K3Nlo4O9xCPWJOESVtccVL4KqK0jf2v7rJjJ4LnZWkkW6Ww5rAIGprV1P9Rk/z82PalMuNIvmUDCGp8OAVWNhOUTUc3WAIvXv2iUXww2Pv8Nml+fI/fZ7+mliKae5EytLGBJzSZ6cwIDAQAB
tom83
Re: copy DKIM
Post by tom83 »
So what would be the trick to make it work? Merge every " " ?
I just would like to know because I have more DKIM to copy and paste.
Thanks.
nikko
Re: copy DKIM
Post by nikko »
tom83 wrote: Wed 18. Dec 2019, 00:27 So what would be the trick to make it work? Merge every " " ?
Thanks.
Correct.
