Primary script unknown error when trying to call a php webpage
lmarcos
Post by lmarcos »
Hi again,
I'm trying to install Dolibarr and Prestashop, the first one in a subdomain created through KH panel and the second one in the domain, but everytime I enter the index.php file url for the installation script I get 'File not found' and the following error on the log.
[proxy_fcgi:error] [pid 8491:tid 139727373702912] [client XXXXXXXXX:37334] AH01071: Got error 'Primary script unknown\n'
The databases are set to local only, Apache settings are the default ones, php 7.2 is supposed to be supported by both programs, I've created cgi-bin folders in both directories, installed the required php packages, enabled fpm, reloaded apache and restarted the servers.
Am I missing some config option on the Keyhelp control panel?
Re: Primary script unknown when trying to call a php webpage
are the folders and file rights correct?
Put a simply php file with phpinfo(); into the webfolder to see if PHP works.
lmarcos
Post by lmarcos »
It's returning the same file not found and the same error log.
/home/users/user/www/domain
Folder permits are 755.
lmarcos
Post by lmarcos »
And php version is 7.2.24-0ubuntu0.18.04.2
Check the owner and group of the folders and files
What does this mean in detail? It is normally not necessary when running Keyhelp.
lmarcos
Post by lmarcos »
Owner ID & Group ID 33 for the domain and one subdomain
Owner ID & Group ID 5001 for the other subdomain
Some other folders not under www have owner ID 5001 and Group ID 33
Keyhelp folder has owner ID 1001 and group ID 33, though and owner & group ID 1001 for the www folder.
lmarcos
Post by lmarcos »
Florian wrote: Tue 28. Jan 2020, 14:40
This means that I thought that maybe some needed packages were missing and that was the reason php wasn't working for those applications because it's working on Keyhelp (you've made a great control panel here, by the way).
Re: Primary script unknown error when trying to call a php webpage
www folder should belong to the Keyhelp User as user and www-data as group and has 750 rights
Subfolders should belong to the Keyhelp user as user and group and have 755 rights
Files should belong to the Keyhelp user as user and group and have 644 rights, files that should be executed need 755 rights
lmarcos
Post by lmarcos »
Florian wrote: Tue 28. Jan 2020, 16:01 Hello,
That solved it, thank you very much, Florian.
One other question, I'm getting the following message with PrestaShop installation needs to write critical files in the folder var/cache. Please review the permissions on your server.
I don't want to mess anything.
check the permission of the folders var/cache inside your prestashop directory if it has got the correct permissions.
Do not set 777! Since PHP is running under the user ID of the Keyhelp user it can create files inside the folder if the folder belongs to the Keyhelp user.
lmarcos
Post by lmarcos »
It must be something else, because I set permissions to 755 on five other folders and it's still telling me Permissions on files and folders
Recursive write permissions for Apache user on ~/img/
PS Edited. Those folders were not missing permission, but owners. Just in case it helps others in the future.
So, once again, thank you very much and have a very nice day, Florian.
