Keyhelp and Tomcat
prune
Keyhelp and Tomcat
Post by prune »
Can you use keyhelp to host and manage a java app with these requirements?
- Support Tomcat 7.0
- Servlet Support
- JDBC Connection
- Java (JSP and Servlet)
Thank you!
Re: Keyhelp and Tomcat
KeyHelp will not configure Tomcat. You may configure it manually as you like.
prune
Post by prune »
Hello Martin,
I meant something like cpanel + tomcat. Can it be keyhelp + tomcat? Cpanel has a plugin for tomcat. So could you run java + php apps on keyhelp?
Does keyhelp allow java? Thanks!
KeyHelp will not manage any Tomcat Applications but you can configure Tomcat by your own, KeyHelp will not interfere with that.
