phpmyadmin increase timeout limit  [SOLVED]
Szektor
Re: phpmyadmin increase timeout limit
Post by Szektor »
Sorry, I meant logout instead of timeout.
Szektor
Post by Szektor »
The link runs to a 404 but I guess you wanted to send me this:
https://www.hostwinds.com/tutorials/inc ... phpmyadmin
However what I would like to achieve is to change this value for all new/existing users by default.
Re: phpmyadmin increase timeout limit  [SOLVED]
There was a .gif at the time I send my answer, but they changed it ;).
You can also put the following into the config file /home/keyhelp/www/phpmyadmin/config.inc.php
Changing the time accordingly to your needs.
ini_set('session.gc_maxlifetime', <TIME>);
$cfg['LoginCookieValidity'] = <TIME>;
However, this config file may be overridden by a KeyHelp update. Do not set this file immutable, as it may break the phpMyAdmin update.
Alternatively use an own instance of phpMyAdmin which you install somewhere on your server an adjust the "Configuration -> Tools -> Database-Administration -> Access URL" to the URL of your phpMyAdmin instance and configure it the way you want.
Szektor
Post by Szektor »
Thank you. This is exactly what I was looking for. :)))
