Doubt about the use of user templates
First apologize for my English .. I use a translator .. please if something is wrong I translate my apologies to everyone.
I am still in the thread for migration to your panel ... I have installed it and its interface is quite easy and intuitive ..
.. but I have not found .. or I don't know if there is the possibility that a user with multiple domains can give direct access to a domain without having to lose the domain of its user panel.
I have not seen how to make a template from a user to a domain .., is this not possible with this panel currently?
Thanks for your time
Re: Doubt about the use of user templates
I currently as admin create a user and give properties to that user indicating some limits of use, and a function that can be performed
cron, ssh, panel entry, number of domains and email account etc.
Design your user template.
My question is when this user that I have added as admin starts to include domains, working on the template that I have created for this user.
The domain added by this user does not have a template to enter the panel, since it is not considered a user, only the admin creates users and assigns templates.
And realemte that's my doubt and question
A domain created by a user ... could not enter the panel to manage their resources?
Do you always need to be created as a user and assigned a resource template by an administrator?
Or can a user who has multiple domains in their account authorize access to the panel of a domain that is under their user account?
Blame it on the automatic translation or my poor english
What is your native language?
Maybe another user can help you better.
No es su traductor .. es mi mala traducción (google) ya es incorrecta
Mi idioma es Español ... yo le voy a escribir en español para que la traducción esté mas correcta.
Yo actualmente trabajo con 2 paneles libres en mis pequeños VPS no me parece correcto indicar sus nombres por que realmente no resuelven mi duda.
Yo he instalado KeyHelp (la instalación y el funcionamiento es un éxito me he sentido bastante cómodo con su forma de trabajar)
Mi duda es la siguiente:
Yo con mi usuario de administrador he creado un usuario para acceder al panel.
Este nuevo usuario dispone para incluir en su área 10 dominios, 10 cuentas de correo, 10 bases de datos etc.. (plantilla 1)
Yo conecto con mi usuario creado al panel .., todo correcto, puedo hacer mis dominios, correos, etc...
Y es en este punto donde se produce mi pregunta ..
desde mi usuario no administrador ¿ no es posible crear unas plantillas para los dominios de mi área ?
Si yo necesito que un dominio administre sus recursos (bases de datos, ftp, correos) necesito informar a la cuenta administradora para que diseñe una plantilla para ese dominio y sea un usuario.
No existe en Keyhelp una forma de que un usuario con varios dominios .. pueda crear una plantilla para uno de sus clientes y pueda generar un acceso al panel.
Gracias por tu tiempo
select name from me;
Mit freundlicher Unterstützung von deepl.com/translatorGuten Tag...
Nicht Ihr Übersetzer ... ist meine schlechte Übersetzung (google) ist bereits fehlerhaft
Meine Sprache ist Spanisch ... Ich werde Ihnen auf Spanisch schreiben, damit die Übersetzung korrekter ist.
Ich arbeite derzeit mit 2 freien Panels in meinem kleinen VPS. Ich glaube, es ist nicht korrekt, ihre Namen anzugeben, da sie meine Zweifel nicht wirklich ausräumen.
Ich habe KeyHelp installiert (die Installation und der Betrieb ist ein Erfolg, und ich habe mich mit seiner Arbeitsweise recht wohl gefühlt)
Meine Frage ist folgende:
Ich habe einen Benutzer mit meinem Administrator-Login für den Zugriff auf das Panel erstellt.
Dieser neue Benutzer muss in seinem Bereich 10 Domains, 10 E-Mail-Konten, 10 Datenbanken usw. angeben. (Vorlage 1)
Ich verbinde mich mit meinem erstellten Benutzer mit dem Panel ..., alles korrekt, ich kann meine Domains, E-Mails, etc. machen.
Und genau an diesem Punkt stellt sich meine Frage ...
von meinem Nicht-Administrator-Benutzer aus, ist es nicht möglich, Vorlagen für die Domains in meinem Bereich zu erstellen?
Wenn ich eine Domäne zur Verwaltung ihrer Ressourcen (Datenbanken, ftp, E-Mails) benötige, muss ich das Administratorkonto informieren, damit es eine Vorlage für diese Domäne entwerfen und ein Benutzer sein kann.
In Keyhelp gibt es keine Möglichkeit, dass ein Benutzer mit mehreren Domains ... eine Vorlage für einen seiner Kunden erstellen und ein Login für das Panel generieren kann.
Vielen Dank für Ihre Zeit
Übersetzt mit www.DeepL.com/Translator (kostenlose Version)
En Keyhelp el administrador puede establecer si el usuario puede añadir más dominios.
En Keyhelp el administrador puede bloquear ciertos nombres de dominio.
Cita de Keyhelp
Si se establece en 0, las cuentas de administrador pueden seguir asignando un número ilimitado de dominios principales y el usuario no puede eliminar los dominios principales que se le han asignado.
¿Esa fue tu pregunta?
Traducción realizada con la versión gratuita del traductor www.DeepL.com/Translator
Nicht genau
Ich verstehe, dass der Administrator alle Aktionen ausführen kann. Meine Frage ist, ob ein Benutzer, der kein Administrator ist und einige Domänen in seinem Konto hat
... können Sie eine Domain in Ihrer Nähe angeben, die Sie im KeyHelp-Bereich aufrufen können, um beispielsweise ein E-Mail-Konto zu erstellen.
Was ich jetzt in KeyHelp sehe, ist das
.. Administrator erstellt einen Benutzer und legt Domänenlimits fest.
.. Benutzer setzt Domains
.., aber die Domain kann das KeyHelp-Bedienfeld nicht aufrufen, um ein E-Mail-Konto zu erstellen. Sie muss den Benutzer, der ihre Domain eingegeben hat, informieren, um ein neues Konto zu erstellen.
Also meine Frage
Erlaubt KeyHelp nicht, dass eine Domain das Panel betritt? .. Es hängt immer von einem Relleser ab, Aktionen innerhalb seiner eigenen Domain auszuführen.
Administrator erstellt Reseller
Der Reseller greift auf Ihr Panel zu und erstellt Benutzer (Domains).
Die Domain kann nicht auf ihr Panel zugreifen und verwaltet ihre E-Mail-Konten, FTP, Datenbanken usw.
Für eine einfache Verwaltung wie das Erstellen eines neuen E-Mail-Kontos hängt es immer von Ihrem Reseller ab
Ist Ihre Eingabe derzeit nicht möglich?
Nochmals vielen Dank für alles
¿De dónde eres? ¿España?
Esto no es posible actualmente.
Funciones para revendedores (sub-usuarios) están en planificación, pero aún no se han puesto en práctica. Los "usuarios" en KeyHelp siempre son usuarios finales que sólo pueden administrar sus propios dominios, bases de datos...
Podrías usar la API para realizarlo. Sería una posibilidad.
Ja... ich komme aus Spanien,
danke für Ihre Antwort ... die Verwendung einer API ist etwas, woran ich im Moment nicht gedacht habe ... ich müsste eine Menge Code in meinem Verwaltungssystem ändern, um dem Unterbenutzer einige minimale Aktionen zu ermöglichen.
Ich fand KeyHelp ziemlich vollständig... Ich kannte dieses Panel nicht und ich mochte seine Umgebung... Ich werde Ihre Änderungen verfolgen und für ein persönliches Projekt habe ich es bereits in Betrieb.
Vielen Dank für Ihre Antwort.
Grüße aus Spanien ...
