Сron email notification [SOLVED]  [SOLVED]
majorboobage
Post by majorboobage »
Here's the thing.
I am using goaccess with cron:
/usr/local/bin/goaccess -p /usr/local/etc/goaccess/goaccess.conf -a - /home/users/USERNAME/logs/access.log -o  /home/users/USERNAME/www/mysite.com/access.html
Notification: On Errors
As you can see, the task completed without errors (Success).
But each time, after completing the task, a letter arrives.
So, if the operation is completed successfully, why does the letter come? :?
Re: Сron email notification (probably a bug)  [SOLVED]
it's seams not a bug, at least from the KeyHelp perspective.
The reason you receive the message is, that the goaccess script seams to writes its output ("Parsing... [258] [0/s]....") not into the normal "stdout" (Standard Output Stream) instead to the "stderr" (Standard Error Stream).
If the cron daemon, responsible for executing cron jobs, detects a non empty "stderr" it considered it as an unsuccessful execution of the script, even if the return code of the script was 0 (which means success).
For fixing this behavior, you can redirect the stderr stream of the goaccess script to the stdout stream by appending " 2>&1" to the command within KeyHelp (without the quotation marks of course).
For verifying, my above assumption is correct, please have a look into the crontab config file via "crontab -u <NAME_OF_THE_KEYHELP_USER> -l".
Right now, the command should look like:
[...] /usr/local/bin/goaccess -p /usr/local/etc/goaccess/goaccess.conf -a - /home/users/USERNAME/logs/access.log -o  /home/users/USERNAME/www/mysite.com/access.html > /dev/null
After you have done the fix mentioned above, it should look like:
[...] /usr/local/bin/goaccess -p /usr/local/etc/goaccess/goaccess.conf -a - /home/users/USERNAME/logs/access.log -o  /home/users/USERNAME/www/mysite.com/access.html 2>&1 > /dev/null
majorboobage
Re: Сron email notification [SOLVED]
Hi.
it worked! thank you very much Alexander!
p.s yes, looks like it is old bug/feature :? https://github.com/allinurl/goaccess/issues/467
